Magica
Joined: 07 Apr 2006 Posts: 11 Location: United Kingdom Thanked: 0 times
Posted: Tue May 16, 2006 11:29 am Post Subject: Spurs, how many? |
Can someone clarify and advise please? I would like to know if I can run 2 spurs, each supplying 2 SINGLE sockets from a double socket (currently used for kettle and toaster) with no other spurs? The spurs will supply power to 1. Washing machine 2. Extractor hood, therefore not in constant use. Thanks |
divadoll_1
Joined: 14 May 2006 Posts: 71 Location: Kent, United Kingdom Thanked: 0 times
Posted: Tue May 16, 2006 2:24 pm Post Subject: |
As I understand the regulations you can only put ONE spur from ONE socket on the mains, but it can be a double outlet. If you need two..then find another socket unless it is a fused spur then it can be run like a radial |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
