Kenmore Agitator
22 May 2006
How do you access underneath the agitator?
glass cup fell in washer and shattered.
I need to get under the agitator to clear
all pieces remaining?
hold fin firmly with one hand and turn the very top portion of agitator counterclockwise with the other. after the top is off just lift the cover off. however, if there is glass between the tubs, you will need to get it out also. take the top off, remove the five bolts at the bottom of agitator shaft inside the tub, and lift out tub. i think thats all you have to do to remove the inner tub on this washer. good luck!
