DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
removing outlets and rerouting existing wire
This topic originated from the How to page called Extending a ring circuit using junction boxes
Click here to return to the page called Extending a ring circuit using junction boxes.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
cfasulo
from United States of America
Thanked: 0 times
PostPosted: Tue Jun 06, 2006 5:49 pm    Post Subject:
Reply with quote Thanks
I am taking down a wall in my house and i have a bunch of outlets connected to the same circuit. I want to eliminate the ones on the wall that i am removing but rewire so the outlet on the other side of the room stays live. what should i do? I was thinking about using junction boxes to extend and reroute into the sealing but found out i cant enclose them into the wall.
i am in the US
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Tue Jun 06, 2006 6:34 pm    Post Subject:
i cant give specific advice on US regs but if possible the best option is to use unbroken runs from outlet to outlet
can't you put some outlets near where the ends of the wall you are removing used to be and then route new wring between them?
Back to top
 Alert Moderators
cfasulo
Thanked: 0 times
PostPosted: Tue Jun 06, 2006 7:00 pm    Post Subject:
so if i am eliminating the outlets on the wall i am taking down and just cut the piece of the wire going from the circuit box and reroute it to an outlet that is on another wall would that be fine. And then i guess the outlets will run like normal. Cause all of these outlets that i am talking about every outlet in the livingroom is connected to the same circuit.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Adding a new light to existing light switch....2 Pole switch 3 900 Thu Feb 05, 2004 1:43 pm
US Existing Fixture to be tapped into adding a new light 5 920 Sat May 22, 2004 9:46 pm
ceiling wiring - multiple or single strand wire? 2 1120 Tue Jan 01, 2008 4:29 am
Having problems feeding a wire to my loft 2 800 Tue Mar 10, 2009 3:59 pm
Neutral wire not working 4 1140 Mon Aug 20, 2007 1:52 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
