DIYnot
Local | Network
   DIYnot > Forums
Local | Network
joing polycarbonate sheets
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
seneca
from United Kingdom
PostPosted: Thu Jun 08, 2006 7:11 am Reply with quote
I want to replace my worn out shed roof with some polycarbonate sheets. I know where I can get some second hand cheap ones, but I can't get hold of any cheap glazing bars to join the sheets. The shed is 2.5m square. Is there another way of joining them that will also be waterproof? Also, how do you join the end sheets? Do you need a special kind of bar for those?
thanks.
Back to top
 Alert Moderators
bendylow
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jun 16, 2006 7:36 pm Reply with quote
sorry,the only way to guarantee no leaks is to use glazing bars,the ends of the sheets need to be sealed with breather tape to prevent condensation build-up in the sheets.then you buy a cap for the end of the sheet and cut it to length and push it on over the tape.
Back to top
 Alert Moderators
Glassman
from United Kingdom
PostPosted: Tue Jun 20, 2006 12:46 pm Reply with quote
Are you using twinwall polycarbonate? If so, then this is probably the cheapest way to do it.
www.twinfix.co.uk
LINK: http://www.twinfix.co.uk/twinfix_ref_261_1.htm
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Sun Jun 25, 2006 8:51 am Reply with quote
Just on the offchance you are using 10mm poly, you can get a 5 metre length of H section for about a fiver and a length of starter trim for the same price. Use these to join and end the poly and afterwards support the joints with some wood.
Thats the cheapest thing i can think of.
mwroofline
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
joing new grp roof to neighbouring mineral felt 4 220 Thu Jul 07, 2011 10:37 am
Polycarbonate Sheets 2 940 Wed Jan 30, 2008 3:13 pm
Advice on fitting 25mm Polycarbonate sheets - Updated 19 3220 Fri Apr 02, 2010 11:01 am
Slipping Polycarbonate roof sheets 4 360 Wed Jul 14, 2010 6:46 pm
Polycarbonate Roofing Sheets 7 2260 Fri Oct 19, 2007 10:13 am
DIYnot
