DIYnot
Local | Network
   DIYnot > Forums
Local | Network
bosch combi red light keeps flashing
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
martinb
from United Kingdom
PostPosted: Tue Jan 06, 2004 9:44 pm Reply with quote
please help...boiler is a worcester bosch 24cdi ...problem is when the boiler is about to come on for the heating it suddenly shuts down and the red light on the front facia starts to flash and all stays shut down until we hold the red button in for about five seconds...this is beginning to happen on a regular basis...could you tell me what the problem is...thank you in advance.
Back to top
 Alert Moderators
COG
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jan 06, 2004 10:34 pm Reply with quote
If its the ch light thats flashing slow then it indicates burner lockout ie its failed to light or failed to register its lit. If you can see a spark at the start then it could be just the min setting on the gas valve is too low or a faulty valve but basically to technical for a diy'er unless your qualified to use a manometer and an avo.
Back to top
 Alert Moderators
Sarahj
from United Kingdom
PostPosted: Sat Apr 10, 2004 7:28 pm Reply with quote
Just found this old post - I have the same problem with my Worcester 24cdi. How did you resolve it?
My pressure is nearly on zero. I was told I need a 'plug' to insert in the bottom of the boiler to enable the taps to fill it.
Not sure where I can get one from. Any ideas appreciated.
Back to top
 Alert Moderators
chuckles
from United Kingdom
PostPosted: Sat Apr 10, 2004 9:22 pm Reply with quote
When your boiler was installed did the installer leave a white filling key with you? I know very little about boilers, central heating, etc., but we have the same boiler as you and we have this filling key which is put into the bottom of the boiler to re-pressurise it. So far never had to actually do it ourselves, because it is always ok until the annual service when the service engineer does it for us. If you haven't got a filling key, may be an engineer would carry one?, or perhaps you may be able to get one from Worcester Bosch? Sorry can't be more help.
Back to top
 Alert Moderators
COG
from United Kingdom
Thanked: 1 time
PostPosted: Sun Apr 11, 2004 10:30 pm Reply with quote
The key you want is available direct from Worcester or your local "boiler spares " will get the number for you in the morning
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sun Apr 11, 2004 10:38 pm Reply with quote
thats good service for a bank holiday
Back to top
 Alert Moderators
Sarahj
from United Kingdom
PostPosted: Mon Apr 12, 2004 3:22 pm Reply with quote
Thats excellent service for a bank holiday!!! Many thanks to all. Yep that number would be real handy.
Sarah
Back to top
 Alert Moderators
COG
from United Kingdom
Thanked: 1 time
PostPosted: Mon Apr 12, 2004 8:10 pm Reply with quote
If your boiler is over one year old then the part number for the chargeing link key is 87161211070, the newer models have a smaller key.
Back to top
 Alert Moderators
plumb
from United Kingdom
PostPosted: Mon Feb 18, 2008 9:56 pm Reply with quote
The worcester is supplied with a key instead of conventional filling loop! If your pressure gauge is near zero & you don't have key go to any plumbers merchant and order one it plugs in to the right of centre from underneath next to a small black knob once key is inserted and turned 90degrs turn small knob & bring pressure up to about 1.4-1.5 bars cold. Pressure switch should stop boiler working below 1 bar
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 910 times
PostPosted: Mon Feb 18, 2008 10:01 pm Reply with quote
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Tue Feb 19, 2008 1:14 am Reply with quote
holty wrote:
I hope the OP is a patient type
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
halstead combi boiler flashing power light and won't ignite 7 1040 Tue Sep 23, 2008 6:21 pm
Britany 80 Combi - Clicking 60 light flashing 12 480 Mon Feb 01, 2010 6:02 am
baxi combi 105e flashing light ( sensor fault light 11 ) 3 1320 Thu Dec 20, 2007 12:37 am
Worcester combi boiler 28cdi red light flashing 31 1600 Sun Dec 29, 2013 2:01 pm
Worcestershire Bosch Greenstar 24Ri Flashing 2 900 Sat Jan 09, 2010 4:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
