was wondering if there is a yearly rounting for bleeding the radiators. every fall or spring? what is the maintainece for hot water heat? thank you for your help
Rounting?? One to look up in a US/UK dictionary!
It isn't critical, though if you have a sealed system you might lose pressure when you do it.
Bleeding is not always required at all. If you have more than a pretty small amount, something's wrong.
I tell my customers under no circumstances bleed radiators without asking for my free advice first.
Too many feed tanks on open systems are full of sludge that could enter the system. Many sealed systems rely on trapped air in the rads since the expansion vessels may be low on charge pressure.
Bleeding rads without checking a few things few can trash the system.
When I wa 5 there wasn`t C/H in any of the houses round our parts 1968 moved and had night storage........1974 installed solid fuel for Mum+Dad.....2006 still no gas in the bloody village
