DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Whirlwind Bath
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
billmck02
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 30, 2006 11:51 am    Post Subject:
Whirlwind Bath
Reply with quote Thanks
I recently installed a whirlwind bath but the cable from the pump was too short so I extended it using a gang underneath the floor boards.
All my floors have been boarded now, bonded, underlayed and carpeted .
The cable enters the back of a 45 amp fused socket on the bedroom wall but have not attached to the mains supply yet via another plug socket.
Can I use another piece of short flex cable with a normal 13 amp fuse attached on one side and plug it into the existing socket which is not a spur and attach the other end into the back of the 45 amp fused socket?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Gareth Trojan
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jun 30, 2006 12:24 pm    Post Subject:
Hmmm thats not very clear dude. Are you an electrician?
The pump, i take it needs a permanent supply. If this 45A switch you mention is for the shower you cannot just extend the flex and connect it into that. If there is a problem the cable will melt before the circuit protection operates.
It sounds like the bedroom is the best place for a switch fused spur unit. The feed for this can be spurred off the nearest socket outlet with 2.5mm cable. You will need to put the correct sized fuse in the spur unit.
What is the rating of your pump (in amps or KW)? I hope the size of the flex you connected is a suitable size as your lovely new flooring will have to come up if it's too small. icon_biggrin.gif If it is less than a few amp then 1.0mm or greater will be ok. Using a plug and soxket would work for this but it's a bit of a rubbish method. Do a proper job and use a spur unit.
__________________
Counter Strike, Guinness and Women. In that order
Back to top
 Alert Moderators
billmck02
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 01, 2006 10:47 am    Post Subject:
Re: Whirlpool Bath
Dear Gareth,
I have a city & Guilds for basic electrical but have not touched any electrical work since 1999 so I am very rusty.
The pump is 2.2 amp and already has a cable all I done was used a slightly thicker cable [1.5mm2] and a gang to extend it enough to reach the bedroom.
The 45 amp socket is brand new for the sole purpose of the whirlpool, so this is my spur and it sits directy beneath the main existing socket.
Thank you very much for your quick response and advice
The cable I intend to use to connect the spur to the main socket is the same cable I used for the extension [1.5mm2]
Yours sincerely
Bill Mckechnie
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Jul 01, 2006 10:57 am    Post Subject:
Re: Whirlpool Bath
what do you mean by
billmck02 wrote:
........a gang .........
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sat Jul 01, 2006 12:33 pm    Post Subject:
what do you mean by a 45A fused socket? Any chance of a couple of photographs? Is your supplementary bonding in place?
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sat Jul 01, 2006 3:24 pm    Post Subject:
This shoud be connected using an FCU fitted with a 3A fuse, and not a 45A socket icon_question.gif . I am presuming by this you are refering to a 45A DP switch, which you plan to spur off an existing socket on the ring circuit. If this is the case then you must not install it this as the small 1.5mm² flex which feeds the pump would only be protected by by the 30 / 32A fuse in your consumer unit. You should feed the FCU from the socket using 2.5mm² cable, and then connect the flex that feeds the pump to the load side of the spur. This will then mean the 1.5mm² flex (and the pump) are protected by a 3A fuse. I am also a bit concerned as to how you have extended the flex under the floor. What is this 'gang' that you talk of?
Back to top
 Alert Moderators
billmck02
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 02, 2006 4:06 pm    Post Subject:
I refer to a gang scottish term for a bunch, A small flat oblong box with three terminals inside to connect brown live, blue nuetral and earth in one side ie the pump side and the same connecting on the other side that leads to the bottom terminals of the 45 amp switch. using the 1.5mm 2 cable attached to the top of the switch coming out and a 13 amp fused plug puched into the main socket.
I have also used an extra earth cable from the back box onto the eart terminal of the 45 amp switch
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun Jul 02, 2006 4:40 pm    Post Subject:
Does it look like this?
Also if you are running the pump off a plug top then there is no need for an isolator switch, and as the pump uses only 2.2A a 45A switch is totally unsuitable. The terminals will be to large for the cable you are using for starters.
What made you think you needed this switch? You say you have fitted a link to the back box. Is the switch flush mounted?
Back to top
 Alert Moderators
billmck02
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 03, 2006 5:05 pm    Post Subject:
1. The pump 2.2amp
2. Cable from pump joined under floorboards by a cable connecter
3. Slightly thicker cable from connector to Marbo 45A DP 1G Sw + Neon
5. From Marbo [1.5mm 2] cable with 13 amp fused plug on end
6. This plug fits into main existing socket.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon Jul 03, 2006 5:43 pm    Post Subject:
We gathered this from you previous posts.
Back to top
 Alert Moderators
Briansmad
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 03, 2006 7:24 pm    Post Subject:
I would just hope everything is water tight and watersealed, if it were to leak, normally near the pump or connections to pump it would certainly be dangerous!!
Back to top
 Alert Moderators
billmck02
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jul 04, 2006 1:53 pm    Post Subject:
The pump instructions were to make sure the 13 amp was plugged into an RCD with a minimum of 16 amp.
Originally I removed the 13 amp plug and replaced it with an RCD 16 amp and plugged it directly into the mains but an electrician who came to do other work said this was unappropriate and advised I spur from the mains with this 45 amp.
Obviously I am not as clever with electrics as I originally thought.
I will get another electrician to redo my mess.
Thanks to all who helped with your advice.
Best to be safe not sorry
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Jul 04, 2006 2:17 pm    Post Subject:
¿Que?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
soontobe
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 17, 2007 12:54 am    Post Subject:
rcd
did exactly the same not too long ago. fitted 16 amp rcbo nexto old wylex fuse board, was then told that you could buy rcd fscu's,for this purpose. is this true ?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Nov 17, 2007 5:30 pm    Post Subject:
Suggest you post a new topic instead of hijacking a crusty old one. Its not helpful to read thru stuff from the Jurassic period and then find you've added on something that is nothing to do with the thread.
Where's my beer??????
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
help please with supply to bath pump 24 720 Sat Jan 26, 2008 5:34 pm
Under the bath 4 384 Sat Dec 22, 2007 4:21 pm
Wiring for shower pump and jacuzzi bath 11 1900 Tue Dec 18, 2007 6:04 pm
Wiring costs for 5 bed, 2 bath, 4 floor, 4500sq ft house? 19 1080 Sun Oct 28, 2007 4:45 pm
bath pump 3 181 Tue Jan 29, 2008 5:15 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
