DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hot radiators but cold water.
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
DickieMint
from United Kingdom
PostPosted: Tue Jul 04, 2006 7:41 am Reply with quote
I wonder if anyone can help.
Ran the tap today but only cold water came out of the hot taps. Flicked on the heating and the radiators instantly went hot (lovely this morning!). I\\\'ve got a non-vented pressure system. Any ideas as to what may be wrong?
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jul 04, 2006 8:20 pm Reply with quote
Do you mean a sealed (unvented) heating circuit or unvented hot water?
Are your taps fed by a combi boiler or unvented\vented cylinder.
Back to top
 Alert Moderators
DickieMint
from United Kingdom
PostPosted: Tue Jul 04, 2006 8:29 pm Reply with quote
Thanks for getting back to me. I'm going to appear so ignorant here...I'm not sure what the answer is!
I've got a Potterton Myson Apollo boiler which does the heating and hot water. To build the pressure up, I have a tap like device which builds it up on a dial in my airing cupboard.
Apologies for being so dumb but that's why I've come on here for help.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jul 04, 2006 9:09 pm Reply with quote
See if there is a brand name\info on the actual cylinder. nad any other boxes\valves etc installed on the pipework.
The more info the better the chance of a remedy.
Back to top
 Alert Moderators
DickieMint
from United Kingdom
PostPosted: Thu Jul 06, 2006 6:43 am Reply with quote
Hey bster,
I've found the problem. I got 2 silver honeywell boxes on the pipes (one switches water to rads the other to taps), the tap one is faulty. I guess if I get that one replaced I'll be sorted.
Thanks for your help.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jul 06, 2006 7:34 am Reply with quote
If the box (2-port valve) is feeding the coil in the cylinder you will be able to manually override the valve (if its not seized) to provide hotwater until it is replaced - look for a little lever on the box.
Back to top
 Alert Moderators
DickieMint
from United Kingdom
PostPosted: Thu Jul 06, 2006 8:02 am Reply with quote
I got hot water out my tap!!! Thanks for that, bster. You were right..I found the little lever. Great advice.
Back to top
 Alert Moderators
bster
from United Kingdom
Thanked: 1 time
PostPosted: Fri Jul 07, 2006 6:10 am Reply with quote
No prob.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Fri Jul 07, 2006 7:19 am Reply with quote
I don't mean this unkindly, but that's most definately a guess, judging by what you've written on this topic.
How have you determined that the motorised valve is faulty?
And BTW - do you know that you can replace the powerhead on the Honeywell valve (if it was made after 1986) without draining down, and it's cheaper too?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
random cold radiators and temperamental hot water 2 780 Fri Nov 18, 2005 4:28 pm
Hot water, cold radiators 2 40 Sat Nov 16, 2013 11:02 pm
Radiators stone cold but plenty of hot water though! 2 940 Thu Oct 02, 2008 11:20 pm
Hot water but cold radiators 5 3900 Mon Nov 17, 2003 5:38 pm
Trianco Boiler working, radiators cold , no hot water. 8 100 Sun Jan 23, 2011 3:13 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
