PEA
Joined: 05 Jul 2006 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Jul 05, 2006 12:28 pm Post Subject: Bathroom fan/cooker hood |
The bathroom fan in my flat has packed in and i need to replace it. It goes out through an approx 3m duct (inside plasterboard covering) along a wall and then along the living room ceiling to the outside. The bathroom is approx 2m x 3m. Are there any special requirements I need given the length of the duct?
Also, the kitchen backs on to the wall where this ducting runs. Would it be possible to fit a cooker hood or kitchen extractor to feed into the same ducting? Would both still work alright?
Many thanks |
Job_n_knock
Joined: 04 Jun 2006 Posts: 198 Location: Kent, United Kingdom Thanked: 0 times
Posted: Wed Jul 05, 2006 4:45 pm Post Subject: |
You might end up with the smell of food in your bathroom. I would have thought a like for like when selecting new fan. Kitchen should have its own ducting really |
RF Lighting
Joined: 31 Mar 2006 Posts: 10752 Location: Birmingham, United Kingdom Thanked: 73 times
The Jeep
Joined: 22 Jun 2006 Posts: 249 Location: London, United Kingdom Thanked: 0 times
Posted: Wed Jul 05, 2006 10:16 pm Post Subject: |
Interestingly, I am looking at a similar solution. Obviously the two ductings can't be linked, but what about if they both exit the building at the same place via a double outlet. Screwfix do a 'pipe to channel' adaptor which seems to take a 100mm pipe and convert it to a 110x54 rectangle. Perhaps two could be put side by side in the space of one vent brick? Actually, the adapters would probably have to be placed further back, with the final two runs to the exit being completed in flat channel ducting...
It might just work...(or would the smells still mix outside the building? I wouldn't have thought so). |
