DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New Combi Boiler and Existing Shower Problem
This topic originated from the How to page called Planning a shower
Click here to return to the page called Planning a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
dozer
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jul 05, 2006 12:42 pm    Post Subject:
Reply with quote Thanks
I'm about to replace my old system boiler with a new combi Vaillant EcoTec Plus 837. I'm wondering if anyone can recommend what I should do with our shower. It's an Aqualisa Quartz A2 that works by mixing the hot water from the cylinder with cold from the mains, and has a pump to increase the flow; the on off switch/temp controller is electronic. I think I have three options: 1) Try using it and see what happens and risk knackering the whole thing (could be very expensive); 2) As recommended by Aqualisa, replace the control unit (which contains the pump) with an "operator" and fit a new on-off switch (horrendously expensive), 3) Try disconnecting the wires to the pump within the control unit and hope that the electronic mixer controls still work.
Has anyone else tried this or can anyone give some advice?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Advice on existing thermo power shower with new Combi Boiler 4 1140 Mon Mar 12, 2007 9:27 am
Adding 'Power' Shower into Basement Flat with Existing Combi 7 600 Wed Jun 02, 2004 11:01 pm
New boiler installation with existing Mira 415 shower 2 300 Fri Jan 25, 2008 8:58 am
Fitting new combi boiler using existing single pipe system 3 580 Wed Jun 11, 2008 9:55 pm
Installing a Shower Pump to an existing Gravity Fed Shower 5 4880 Fri Oct 12, 2007 10:24 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
