Just moved 2 rads (replaced one with a new rad as the pipe-work went under the floor of an extension and gave the odd problem cold unable to bleed out ) I an now having problems getting the air out not sure if have a intermittent blockage in supply or return pipe not sure what type the system is called boiler is wall mounted B/F 10 year old Ideal Classic pipe work 22m/m supply and return with a manifold with 4 rings of 8m/m pipes on each to the rads I had a problem last Christmas time 3 rads not working suspect a blockage in the 8m/m pipe-work from the manifold to the rads on that ring but one night the air locked moved and all was OK from then on .
Some of the rings are working both up and down the ring I have broken into does not warm up but bleeds and full of water.
Please could someone tell me to correct method to drain a system down
as closing the cold supply valve & opening the drain valve that drains down the boiler plus draining down the ring I worked on did not completely drain the system . I have just emptied by removed all the sediment from the expansion tank in the attic very dirty and replaced with normal water until `I can get the system to work properly .
Any suggestions would be very welcome
