DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
shower water pressure
This topic originated from the How to page called Choosing a shower
Click here to return to the page called Choosing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
tmnelson
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 20, 2006 1:56 pm    Post Subject:
Reply with quote Thanks
In summer when water pressure is low, the water temperature is scalding!! We have a gainsborough energy 2000x shower with a cold water feed[shower heats the water itself] from a combi boiler situated on ground floor. Can we install a pump to improve the flow ?? will be grateful for any helpful replies- Thanks. icon_lol.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Jul 20, 2006 7:18 pm    Post Subject:
Re: shower water pressure
And if you have an electric shower then you shouldn't feed it from the combi!
Not unless you have some stored water somewhere....
Back to top
 Alert Moderators
tmnelson
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 20, 2006 8:16 pm    Post Subject:
icon_redface.gif sorry I assumed that the water supply came via the combi boiler, not from a main feed. We don't have a tank in the loft though it was removed when the combi boiler was installed. the shower was installed at a later date, is this type not compatible ?
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Thu Jul 20, 2006 9:01 pm    Post Subject:
I think what softus is meaning that you wouldn't feed an electric shower from a combi boiler as the shower heats the water itself. A normal electric shower requires a mains water feed, not from a header tank although it is possible to buy an electric shower which has an internal pump which must be fed from a header tank. These can be installed where there is a water pressure problem.
IIRC there is a rule which prohibits pumping water from the mains, our plumbing friends will likely know better.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Jul 20, 2006 10:22 pm    Post Subject:
The Water Regulations prohibit pumping from the mains at anything above a tiny tate (0.5 l/minute or something - I forget the precise figure). This is to prevent a low pressure condition in the mains that could drag in impurities and/or create a syphon elsewhere.
Are you saying that you can't reduce the temperature on the shower, to be below "scalding"? If not then the shower is faulty and needs to be fixed.
Back to top
 Alert Moderators
tmnelson
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 21, 2006 11:40 pm    Post Subject:
Usually when the weather is 'normal', the temperature/ flow rate is ok but in the summer even with the shower set to low and the gauge turned to cold, the water is still far too hot. icon_confused.gif
Back to top
 Alert Moderators
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Sat Jul 22, 2006 7:03 am    Post Subject:
Sounds like a fault with the shower. Could it just be that the shower head is blocked? Remove the head from the hose and see if the water temperature is OK then.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
tmnelson
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 23, 2006 6:35 pm    Post Subject:
shower water temperature
Dear chrishutt, thanks for your suggestion, descaled the showerhead, but its made no difference, water still scalding !!, anyone else out there have any ideas icon_sad.gif
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Sun Jul 23, 2006 9:32 pm    Post Subject:
CHeck the input pipe to the shower - it should be COLD and not from the combi.
Then check the flow rate from the shower, whcih should go to something above 4 litres/minute. T hat rate you would get water at about the right temperature, assuming it's 10 kW or so.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Loss of hot water pressure on a mixer shower 5 1500 Sat Jul 19, 2008 6:57 pm
Shower/washing machine - water pressure problem? 2 340 Sun Jan 07, 2007 12:55 pm
Low water pressure for a shower 2 3520 Fri Aug 13, 2004 9:50 am
Electric Shower Water Pressure Low 2 380 Tue Jan 16, 2007 7:32 pm
low water pressure - electric shower does not work now 7 600 Wed Nov 07, 2007 1:17 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
