DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
water damage to wood block
This topic originated from the How to page called Wood block / Parquet floors
Click here to return to the page called Wood block / Parquet floors.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
kissimmee
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 28, 2006 7:02 pm    Post Subject:
Reply with quote Thanks
I would really appreciate your advice on this. I moved into my 30's semi three weeks ago. I bought it because all the period features were in situ, including original pine wood block floors to all the ground floor. I sanded them in preparation for varnishing...but disaster struck last weekend. The cold water tank split whilst I was out at work. I came home to a flood...and now, all the floors on the ground floor have water stains and damage. My insurers have set up dehumidifiers and fans to dry it all out; but will only say that they can sand the floor after drying is complete, and this "may" remove the stains. I want to save the floors if I can - where should I go for advice? What can I do? What should I ask of my Insurers? Thank you.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Sat Jul 29, 2006 8:55 am    Post Subject:
Depending on how long the water has been on the wood blocks (and pine is soft, so will have absorbed lots) the water marks can penetrate very deep into the wood.
If sanding doesn't clear the black marks, you could ask your insurer for replacement floor or blocks that are too damaged (if you are insured sufficiently that is, and the value of the floor has been correctly calculated and added to the total sum). For a replacement floor (or the occasional blocks that are too damaged) find a reclaim yard.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
 Alert Moderators
kissimmee
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jul 29, 2006 9:50 pm    Post Subject:
Thanks for your reply, WYL. Well I've got £500,000 buildings cover, and £50,000 contents...so it should be covered, yes?
The Loss Adjuster is coming to see me on Monday, I will point out the stains and ask about replacement flooring.
Some people have been saying to me, "it's a good thing, the flood, because you will be able to get things done that you wouldn't have had, without insurance". I just can't see it, myself: I will have to live with all the mess and disruption for weeks yet, whilst everything dries out. I don't know how other folk 'inflate' their claims: I can only think of the things that were truly damaged, and would feel bad if I fabricated anything.
What I would have preferred best is that the flood never happened! All my decorating has to be postponed, the house is a mess and I can't do anything about it until it's dry...pah! And even reclaimed wood block isn't the same as having the original flooring in place. But that's life I guess: one step forward, two steps back. Thanks for your help.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Laminate Floor damage 3 240 Sat Jan 17, 2009 12:04 pm
Concrete floor - installing waste pipe - will i damage dpm? 2 1360 Wed Jan 02, 2008 7:07 pm
Best way to lift floorboards without damage? 3 1780 Mon Mar 19, 2007 12:38 pm
HELP ....sub floor damage.... 4 200 Sat Mar 07, 2009 1:13 pm
Newbie nervous about loft damage 2 180 Wed Oct 07, 2009 12:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
