i have a Philco wm1000se it goes through all the motions fills drains and goes through the various programs but wont spin
the belt is fine
i am unsure as to if the problem is with the motor or the controller.
with a volt meter if i spin the motor it does show a small voltage (500ma with no voltage to the stator or rotor) indicating that there is a circuit on both the rotor and the stator the controller outputs 20v to the stator but nothing to the rotor i am fairly sure that the problem is the controller but other than it not spinning seams to run everything else fine
also have bean unable to find anywhere that can supply a controller for a reasonable price and didn't want get one to find out it was the brushes any help would be greatly apresheated
the belt is fine
