Disconnecting washing machine
30 Aug 2006
Cardiff
Hello everyone! I'm very pleased to have found this forum. Just bought a house and I'm no expert in DIYing so some tips are welcome!
I am having a new washer/dryer delivered tomorrow - Hotpoint. I have disconnected the hot and cold pipes from the back of my old machine, having turned off the supply. However, my problem lies with the over flow. I do not know what to disconnect.
Any tips?
Cheers,
mrtomato.
By overflow I assume you mean drain. Is it a stand pipe or a spigot under the sink? If it's a spigot you need to block it off until the new machine is installed. For a stand pipe, you don't have to do anything.
Apologies in advance for my basic knowledge! There's a grey ribbed pipe coming out from the bottom of the machine. This feeds into the bottom of my sink. This pipe disappears into the washer and at the other end is fixed. Which end should I disconnect??
The sink end, and blank off the the spigot or water will pour out under your sink when you use it.
I am assuming that the blokes fitting thr new one tomorrow will connect a new overflow to the spiggot, so if I disconnect it right before they arrive that will suffice? Trouble is, as the thing is ribbed it is locked tight onto the spiggot and I can't get it off unless I cut it. Is that a problem?
