DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Soundproofing Stud/Partition Wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
kevin_robson
from United Kingdom
PostPosted: Sun Sep 24, 2006 6:49 pm Reply with quote
What is the best thing to use as sound insulation within a stud/partition wall?
I want to try to isolate the sound from the two rooms as much as possible?
Back to top
 Alert Moderators
Static
from United Kingdom
Thanked: 168 times
PostPosted: Mon Sep 25, 2006 10:33 am Reply with quote
Insulation
Back to top
 Alert Moderators
tigtog1
from United Kingdom
PostPosted: Mon Sep 25, 2006 4:58 pm Reply with quote
we use kingspan celotex board cut tight between uprights and noggings although there is probably more sound proof material out there
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Mon Sep 25, 2006 5:38 pm Reply with quote
Any of the proprietary insulation materials will help but if you really want to kill the noise, it has to be a fairly dense medium in there. Why donít you use 100mm blocks? In rooms where it doesnít really matter I would use studwork for speed & convenience but if sound insulation is important between rooms, use blockwork every time; if youíre DIY, itís even probably cheaper on materials but obviously takes longer to put up.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1255 times
PostPosted: Mon Sep 25, 2006 5:40 pm Reply with quote
Rockwool will have better sound insulation properties than Kingspan/Celotex, and a board such as Fermacell will help too
Back to top
 Alert Moderators
Deluks
from United Kingdom
Thanked: 326 times
PostPosted: Wed Sep 27, 2006 3:06 pm Reply with quote
Staggered studs all the way, with 2x12.5mm on one side and a 12.5 and 9mm on the other side. Use rockwool slabs in between, don't use celotex or kingspan, due to it's rigidity it can actually transmit sound.
Do a google on staggered stud walls, and google images as well.
Concrete blocks will work well, but not the lightweight ones, which means you might end up in the room below due to the floor not being able to take the weight. Also 2 seperate plasterboard walls will beat a single 4" concrete wall for soundproofing at higher volumes.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Soundproofing existing stud partition 4 200 Fri Mar 11, 2011 10:30 pm
best soundproofing for partition wall? 6 1380 Sat Mar 25, 2006 8:52 pm
soundproofing a partition 3 660 Thu Mar 27, 2008 6:04 pm
Removing stud partition wall in new build? 15 660 Thu Nov 03, 2011 9:02 pm
relining stud partition for kitchen wall units 9 1120 Mon Apr 05, 2010 7:14 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
