Joined: 01 Oct 2006 Posts: 16 Location: Somerset, United Kingdom Thanked: 0 times
Posted: Sun Oct 01, 2006 10:18 pm Post Subject:
Kitchen spotlights
Hi guys,Just in the middle of wiring my kitchen for mains halogen lights and just realised I am using 1.00mm cable...I am putting 3 banks of 3X50watt lights in. Is this size cable sufficient or do you think I should go to 1.5mm?
Joined: 27 Jul 2006 Posts: 4940 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sun Oct 01, 2006 10:33 pm Post Subject:
Depends on a lot of things. I assume this is the cabling on the mains voltage side to the transformers (or are u using mains halogen?).
In any event, if the circuit leaves the consumer unit as 1.5mm˛ then (as a general rule) you must not use smaller gauge cable elsewhere on the circuit.
Posted: Sun Oct 01, 2006 10:37 pm Post Subject:
wow that was quick Pensdown.thanks alot.......but forgot to say that i can fit a 20junction box to each run..would it be wise to then run 1.5mm to each light?
Posted: Mon Oct 02, 2006 9:39 pm Post Subject:
Thanks both of you......Yes I am well aware of part p...have a nvq3 in electrical maintenance for factory work, mainly motors...but know I need electrical certification...sighh ..........and i'm not really up on current law on downlighting.
I am putting the 20amp jb's @ the edge of the ceiling with feeds to three lights each......but once the new ceiling is up they wont be accessible............is that ok taylor..........thanks once again for your help
Posted: Mon Oct 02, 2006 9:53 pm Post Subject:
Sorry, missed that bit of the OP.
I know there's lots of hidden JBs out there and there are lots of people who drive past my daughter's school at 50mph in a 30 zone. Both are wrong.
Hidden screwed junctions are wrong, its against the regs and its a pain. I mark it as a 2 when i find it on an inspection.
Why hide the JBs where you cant get to them without ripping the ceiling out???, much better to have them just inside one of the holes then you (or the next guy) can access them if a fault occurs.
Posted: Mon Oct 02, 2006 10:00 pm Post Subject:
point taken Taylor......I will alter the wiring to get the jb's up inside the nearest spots. Thanks Ban. i bet your right.but I do like to get things right if I can.
Posted: Mon Oct 02, 2006 10:24 pm Post Subject:
Thanks Taylor,
Can you recommend anywhere to get downlights as well that will take 2 cables and let me wire in parallel?.........all the ones I have seen seem to have a small connection box for one cable!!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
