DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Weird wiring
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
LeeF&AJay
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 5:55 pm    Post Subject:
Weird wiring
Reply with quote Thanks
Hello, hope someone can help us. We've just moved into a house where there are two separate lights in the front room, controlled by a normal double switch. However, there are only 4 wires for both lights, ie switch 1: yellow goes to ~ and blue to L1. Switch 2: red folded over and going into both ~ and L1. This works with the double switch but when we try to use the same setup on a dual dimmer switch, nothing happens. Has anyone got any ideas? Sorry if this has already been posted by someone else. Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Mon Oct 02, 2006 5:57 pm    Post Subject:
more info
where has this "duel dimmer" come from?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
LeeF&AJay
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 6:15 pm    Post Subject:
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 7:06 pm    Post Subject:
can you explain more about switch 2 red folded etc
Back to top
 Alert Moderators
LeeF&AJay
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 7:09 pm    Post Subject:
ok, it's a single wire folded over, it is exposed at the bend and also at the end of the cable, as normal. The bent bit goes into L1 and the end into ~. Hope that makes sense
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 7:19 pm    Post Subject:
no think you are going wrong here somewhere, the red bent over would normally go in one of the C terminals with the end of the red in the other C terminal, it could never work across C and L1 of the same switch. So reds go to the ~ terminal with the yellow and blue as the switched lives. put the old switch back on and try first before trying the new switch
Back to top
 Alert Moderators
LeeF&AJay
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 7:23 pm    Post Subject:
This is a bit crude but may give a better idea:
This is how it was wired before we got here... it doesn't make sense to us but it works
Back to top
 Alert Moderators
fireman22
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 02, 2006 7:25 pm    Post Subject:
yes got that as i said reds go to C terminals or ~ on dimmer yellow and blue are switched lives out
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Oct 02, 2006 8:53 pm    Post Subject:
Try disconnecting all wires from the switch, having isolated first. Then use a choc block to connect (in turn) red to yellow, and red to blue. What happens?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
HDRW
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 03, 2006 9:03 am    Post Subject:
Is this diagram accurate? You haven't swapped the bottom sequence of terminals round? You'll often find that the two switches' connections are arranged in two triangles, inverted with respect to each other, like this:
COM L1 L2
L1 L2 COM
And what catches people out is that they think that each row is one switch, but in fact the top COM is switching between the two bottom Ls and vice versa. So if this is how your old switch was, then you had the red going into the COM of one switch and the L1 of the other, so connecting the lights to the L1 and COM respectively will work.
If this is the case (check the old switch with some type of continuity tester), on your dimmer just connect the red to the two COMs and take the lights from the two L1s, and you've won!
Cheers,
Howard
__________________
Back to top
 Alert Moderators
LeeF&AJay
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 03, 2006 7:34 pm    Post Subject:
Hi HDRW, you're absolutely right, the sequence on our drawing was incorrect -- instead of each row representing one switch, the live wire crossed both. Because the live wire in our case was very short, we've had to get some extra electrical wire and attach it to the one coming out of the wall (using plenty of electrical tape!!), so that it would feed both switches on the dimmer switch. Thanks a lot everyone for your help icon_smile.gif
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Help with weird light-switch wiring in living room 20 620 Sun Jan 21, 2007 10:09 pm
weird economy 7 problem 4 220 Wed Sep 17, 2008 7:21 pm
Weird goings on 16 760 Tue Jul 08, 2008 10:25 pm
Weird RCD Tripping 2 240 Sat Jul 05, 2008 2:25 pm
12 V Bathroom Fan - Weird - help needed. 6 340 Sun Aug 05, 2007 8:53 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
