Machine started leaking water so after and little investigation found that the pipe which feeds from the hot water to the washing powder dispenser has a split, anyone know what this pipe is called or where i could get one, its only a rubber tube.
I am also facing the same problem, can you please tell me how did you came to know that washing powder dispenser has a split.
Your reply will be helpful for me
