DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
single switch ,two lights
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
  View previous topic :: View next topic
Author Message
Nigel2
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 08, 2006 11:01 am    Post Subject:
Reply with quote Thanks
I have a single switch connected to two lights,I have changed one of the lights for a ceiling fan.The problem being when I turn on the light switch the fan comes on and off and the other light stays permently on, can any on help please icon_cry.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Oct 08, 2006 11:08 am    Post Subject:
When you removed the light, how many wires did you find, and what did you do with them all?
Take a look at the diagrams of lighting circuits in the For Referenc topic and/or the Wiki, and you should see where you went wrong...
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
Nigel2
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 08, 2006 11:55 am    Post Subject:
There are 3 cables at the ceiling rose I think they are two ceiling cables and one switch cable. Each cable has 3 wires neutral (Black) Live (Red) and Earth.
I have connected the two neutral wires (Black) of the 2 lighting cable with the neutral of the ceiling fan (Blue) in the same terminal .
I have connected all 3 live cables together in the same terminal
I have connected the neutral (Black) of the switch cable with the Live (Brown) of the ceiling fan in the same terminal. Can you please tell me please what I have done wrong
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Oct 08, 2006 12:02 pm    Post Subject:
I do worry that you are messing with electrics when it is not immediately obvious to you that if you have 2 lights from 1 switch, then one of those "ceiling cables" must go to the other light, and if it is on all of the time then clearly you have connected it to the incoming permanent live and not the switched live....
__________________
Back to top
 Alert Moderators
Nigel2
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 08, 2006 12:13 pm    Post Subject:
Sorry i am not great at electrics, but i did realise that one ceiling rose was connected to the other, plus a switching cable. I suppose what I am asking what wires need to be in the same terminals to rectify my situation
please
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Sun Oct 08, 2006 6:14 pm    Post Subject:
The cable that goes to the other rose has to be connected to switched live & neutral, not permanent live & neutral.
Great at electrics or not, why could you not see that if you want the light to come on when the fan is on, and go off when the fan is off, that you should connect it to the same terminals as the fan?
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
End-of-Run Lights Controlled by (1) single pole switch 2 1980 Mon Nov 28, 2005 1:55 am
wiring three lights to a single switch 3 500 Fri May 02, 2008 9:38 am
2 Lights, double switch to 2 lights single switch 10 740 Sun Aug 07, 2005 2:43 pm
Changing a single socket with a dimmer to power new lights 4 340 Sat Jan 29, 2005 10:45 am
Wiring Up New Single Point Spot Lights on Conservatory Wall 2 160 Sat Jan 24, 2009 6:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
