DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Outside Flood light
This topic originated from the How to page called Positioning wall lighting
Click here to return to the page called Positioning wall lighting.
  View previous topic :: View next topic
Author Message
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 9:10 am    Post Subject:
Outside Flood light
Reply with quote Thanks
Hya dudes,
I'd like to install an outside 300w flood light on my new house. I\\\'m curently wondering if I should run the power from a ring main or internal lighting circut.
Would I need to add a fuse spur and switch box in both cases?
I've got a 300w flood light and some 1.5mm twin & earth and I\\\'ve bought and dry lining box(you know one that sinks into the wall) and a switch fused spur 13Amp. and a 20Amp junction box.
So Have I got the right gear? and which way is usually best these days ring main or lighting circut?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 9:24 am    Post Subject:
It can be done either way
A lot depends on where the nearest circuit is to connect to.
Probably better to take off from lighting circuit as the ring main will/should be protected by RCD and if it trips you'll have no flood light.
No problem using a FCU off lighting cicuit as long as you use a 3Amp fuse in it not 13Amp and to be honest it will be easier to wire in.
Back to top
 Alert Moderators
industryspark
from United Kingdom
Thanked: 1 time
PostPosted: Mon Oct 09, 2006 5:53 pm    Post Subject:
yep, go with the lighting circuit if possible, it'l be much easier to terminate and cram the wires in your fcu.
nice to see this being done properly for a change, seen loads with a flex from the light with a plug on that plugs into a socket inside the house, ok but ugly!
__________________
remember......a little bit of knowledge is often more dangerous than no knowledge at all!
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 7:20 pm    Post Subject:
icon_wink.gif Cheers Dudes,
Looks like I'll be wiring up to lighting circut in the loft and then run it down to switch and out to light.
Whats the story with this artic flex stuff would I need to use some between the junction box and outside light?
And do you think I'll have part P iusses later.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Mon Oct 09, 2006 7:57 pm    Post Subject:
But what about the load? And what if the 300W lamp is changed for a 500?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
industryspark
from United Kingdom
Thanked: 1 time
PostPosted: Mon Oct 09, 2006 8:11 pm    Post Subject:
Fair point secure spark, could be an issue.
300 watt is 1.25A so he should still have enough to play with even if he's got a lot of lights on!
__________________
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 8:29 pm    Post Subject:
icon_rolleyes.gif A big house.....Dude I said it's a new house and these's days they build them small.
Anyway thanx man.
Erm what do you mean by secrure spark?
I figure that I'll take the power from the up stairs lighting ring (cos there's only about 5 lighting points up there and so I'll have more load to spare. I think icon_question.gif
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 9:00 pm    Post Subject:
The load
MMMM Dudes,
I'just done some math and on this 300watt light is 1.25 Amps ok and I've 5x60 watt bulbs which gives me a total of 2.5 Amps.
So If I use 3 Amp fuse in the FCU it'll work yes OK, but If I change any lights later upwards in wattage then what will happen? Will the 3 amp fuse blow or will MCB cut out on CU. I think the MCB is rated at 6 amps, so that ok and should'nt trip out.
I have children so the lights up stairs are likely to be almost all on a some point.
Back to top
 Alert Moderators
industryspark
from United Kingdom
Thanked: 1 time
PostPosted: Mon Oct 09, 2006 9:18 pm    Post Subject:
you will have a 6A mcb in the CU more than likely. this means the entire lighting circuit on this mcb(miniture circuit breaker) can take 6A before it trips.
if 1.25A is used up by your outside light you have over 4 and a half amps left for other fittings on the circuit.
a 60 watt bulb will use roughly 0.25A so you can see that you have enough for a few of these. overloading the circuit shouldnt ever really be a problem ( unless you add more outside lights)
the 3A fcu switch fuse protects only the outside light (or will when irs installed)
__________________
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 9:36 pm    Post Subject:
icon_biggrin.gif Cheers mate thats right I'm abit rusty on this, I did a 236 part 1 about 10 years ago and I've never really a chance to use the knowledge.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon Oct 09, 2006 9:39 pm    Post Subject:
So did I.
Where did you go to college?
__________________
I downlights
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 09, 2006 9:42 pm    Post Subject:
RF Lighting wrote:
So did I.
Kitson college in Leeds west yorkshire.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Mon Oct 09, 2006 11:38 pm    Post Subject:
wow me too.
Did you have the joys of lectures from Malcolm Jackson?
I was also taught by Paul Birkby, Andy raynor, Steve Brough and 'the legend' Mark Gallager
__________________
I downlights
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 10, 2006 7:37 pm    Post Subject:
Dude
Afew of the names ring a bell
Back to top
 Alert Moderators
Rizlaman78
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 12, 2006 11:06 pm    Post Subject:
HI there again,
I'am gonna have to chase a line down the wall to where I want to put the switch for the light.
But does anyone know the minium and maxium depth, for chasing out a wall for a T&E cable & capping?
As I seem to remember something about it, and it was to a certain depth and it had to have a protective capping over it.
My wall is brick and then cavitiy and then breeze block, and then there's a small gap between the plasterboard and the breeze block.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
500 watt flood light V 2 400 Mon Oct 22, 2007 9:25 pm
Quick question re installing a flood light 13 520 Sun Jun 29, 2008 6:48 pm
Flood light staying on 3 280 Thu Jul 24, 2008 8:50 pm
Flood light Cable 7 540 Mon Oct 22, 2007 12:45 pm
Flood light with a dimmer switch 6 260 Fri Sep 26, 2008 5:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
