I have just moved into a ground-floor flat with probably the most pathetic shower ever...
from what i can tell the cold water is at mains pressure all throughout the house and the hot water is coming from a hot water tank who's output is about 5' off the ground floor.
(hot and cold being mixed in one of those shower in bath / mixer tap type things where you pull the lever up and the water goes up to the shower head rather than out the tap)
So what (i assume) i need to do is to boost up that hot water supply so that the hot water can actually get to 7'! (preferably a bit more) and also the mixer will have (closer) to equal pressures (rather than filling up my hot water tank in reverse!)
All of this is in a rented flat so major system modifications are a no-go.
Can i just install a single pump underneath my hot water tank to boost my entire hot water pressure?
if so; what's the cheapest?, can i fit it? - or does it require a seperate electrical circuit?
Any advice/recommendations are greatly appreciated.
Chris
Chris
