Hi everyone.
I am going to attempt to refit my bath. After 6 no shows by 4 plumbers in the last 3 months I have no option. But i need a few tips.
I have a double ended bath with a mixer tap. The nut on the side of the hot tap leaks (I think) and the overflow/pop up waste control moves about and leaks too.
The plan is to remove the bath fix the leaks, fit flexible tap connectors and put it back.
I have no tools or experience so if anyone could give me an idea of what i need so i can pop to my local DIY store.
How do i disconnect the waste and what do i use? Will the plastic connection loosen by hand and if not what tool will i need. I'm concious that it's plastic and i don't want to damage it
The taps are connected by copper pipe. What do i use to disconnect the pipe and is it easier just to cut the pipes since i'm fitting flexible connectors?
How do i stop the overflow from moving and leaking?
And finally how do I fit the flexible connectors?
Any avice would be much appreciated!
