boparob
Joined: 22 Oct 2006 Posts: 16 Location: Bradford, United Kingdom
Posted: Sun Oct 22, 2006 8:31 am |
Hi I had a vokera Compact 24 installed in June 2003 and within the first year I had a Main Circuit Board replaced and some sort of valve replaced that was leaking. All covered under Vokera's 1 year warranty, but in fairness you shouldn't expect many problems within the first five years realistcally (Should you? !!)
Last week we stopped getting any heating or water from the unit, but the green light continued to flash, indicating no problems. The plumber opened the unit and it fired up, indicating a air pressure switch problem? He replaced this and it still refused to light, so the next test indicated another faulty circuit board. When he replaced this it still refused to light, so he looked further to find he'd put a pipe on the wrong way round on the air pressure switch? when he swapped it round it fired up. (This was last night) Within an hour the red light came on, which I reset and it worked fine. Today we have nothing, and every time you reset, the red light comes on.
Any thoughts? So far it's cost me £130 and I still have no heating or hot water, a 3 1/2 year old and a 7 month old and a miffed off wife.
HELP!!!! |
ChrisR
Joined: 24 Jul 2003 Posts: 23083 Location: London, United Kingdom Thanked: 936 times
Posted: Sun Oct 22, 2006 10:53 am |
| Quote: | | Today we have nothing, and every time you reset, the red light comes on. |
Does it do anything towards lighting? Does the fan come on?
Getting the rubber tubes backwards on the APS is often easy to do and wouldn't do any damage.
It could be that the fault wasn't really the air pressure detector but a lack of air pressure. The fan would start though. |
Agile
Joined: 26 Jun 2004 Posts: 45997 Location: London, United Kingdom Thanked: 2523 times
Posted: Sun Oct 22, 2006 11:34 am |
I will assume that the red light is a failure to ignite lockout.
Common causes of that are flue assembly faults and sticking gas valves.
Both of these are really the province of CORGI engineers.
Boilers are fairly complex appliances and inevitably there will be the odd one which has a part fail during the warranty period but this is pretty rare and usually far less than 1%.
You have not mentioned the installer. Normally they are the first port of call if any problems arise with something they have fitted.
I hope this "plumber" is not charging you for parts he has changed which were not necessary. We call them "parts changers" because they cannot diagnose faults and just change things until it works.
Perhaps you really need a "boiler engineer"?
Tony |
boparob
Posted: Sun Oct 22, 2006 6:37 pm |
Thanks for the tips - The plumber returned today (yes he's an installer not just a repairer! When he'd shut the system up a wire had caught between two contacts, so it wouldn't fire up. He didn't charge me for this visit. Circuit board still working touch wood. |
