hotpoint washer dryer
Appears to be coming from a white tubular spout at the back and on the top of the machine. A black cap covered this. Comes straight from the cold water in pipe- Only pours out when drying cycle commences.
The little white tube you describe is the water feed going into the condensor for the dry cycle. The water should be contained in the outer black section.
Thanks for that. Is there any way i can regulate the ammount of water coming through as it appears to be gushing through the spout. Even with the cover on it pours through the top after a few seconds and there doesn't appear to be a blockage down the thick black pipe that leads to the drum.
The water inlet valve has a restrictor in it. No way of adjusting.
