blackfacespikeyhair
Joined: 06 Nov 2006 Posts: 12 Location: Leeds, United Kingdom Thanked: 0 times
Posted: Sat Nov 11, 2006 12:56 am Post Subject: surge protection |
I notice that a lot of multi-way extension leads have surge protection built in. Is it possible to get a surge protector which can be permanently wired into the entire mains supply in the house? |
Big_Spark
Joined: 20 Feb 2004 Posts: 3434 Location: United Kingdom Thanked: 0 times
Posted: Sat Nov 11, 2006 4:25 am Post Subject: |
Yes it is, Hager make MCB sized surge arresters, as do Merlin-Gerin and, I believe, MEM Eaton. These can be installed in an existing Consumer unit, or connected in their own enclosure.
However I would take professional advise or do a LOT of research before installing such devices in an installation as they will need to be rated to the circuits you wish to protect, they are no cheap and installed incorrectly it could be an expensive exersice. __________________ I only do commercial and Industrial so Prescott can shove his Part P tax |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sat Nov 11, 2006 8:53 am Post Subject: |
i would stick with the extension leads, especialy for the pc, as some leads you can run the phone line through them.
in a storm i once had one go (high voltage must have come down the phone line), boy did it go bang
if i have had one in the cu it would have done no good __________________ Do you like music Mr Finch?
Forum = Opinions |
sm1thson
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom Thanked: 0 times
Posted: Mon Nov 13, 2006 12:25 pm Post Subject: |
you can get socket outlest with the surge built in, but for a PC I'd just stick with the extension leads. |
