DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vaillant Turbomax plus 828e F28 lockout code
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Amplegirthage
from United Kingdom
PostPosted: Sat Feb 21, 2004 11:19 pm Reply with quote
Hi I have just found this great site.. Any ideas on this problem. I have a Vaillant turbomax plus 828E Combi. I Powered it off today While replacing a sink, Water was turned off and drained down. After refilling the system and powering on, the boiler shows Error Code F28. This relates to gas supply or ignition. The Sparker is sparking Ok. But it appears to be getting no gas. The gas supply is ok in the rest of the house.
If you press reset it tries to ignite 3 times then F28!
Back to top
 Alert Moderators
CH4
from United Kingdom
Thanked: 1 time
PostPosted: Sun Feb 22, 2004 5:44 pm Reply with quote
If the gas supply to the boiler was turned off then it is possible that there could be air in the boiler's gas pipework. If this is the case, then the boiler will not light until the air is purged (repeatedly trying to re-light the boiler may achieve this).
Back to top
 Alert Moderators
Amplegirthage
from United Kingdom
PostPosted: Tue Feb 24, 2004 10:28 pm Reply with quote
Gas fitter has been twice so far.. tried a new gas valve. Not that!! tried a new control board which spontaneously combusted.. OOPS!! gone away to get more parts..
The moral of this story never assume a gas fitter knows your particular boiler or indeed what he's doing.
We live in hope !
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Tue Feb 24, 2004 10:34 pm Reply with quote
you really want a heating engineer, not a gas fitter
Back to top
 Alert Moderators
Amplegirthage
from United Kingdom
PostPosted: Fri Feb 27, 2004 7:52 pm Reply with quote
Second "heating engineer" arrived wednesday. took a look and said let me take your manual so I can ring Vaillant.. Never been seen again..So tomorrow im off to buy the parts required from hrpc and im going to fix it myself.
After a bit of basic electronic testinga nd one call to Vaillant it turns out the fault is caused by the gas valve cable going short and burning out the relay on the board.
So their you have it F28 code = new board and a cable 200 thankyou and goodnight.. I will never pick up the phone again for a Heating engineer.
Back to top
 Alert Moderators
DIWHY99
from United Kingdom
PostPosted: Sat Oct 09, 2010 12:26 pm Reply with quote
I had an F28 fault code on my Vialliant boiler about three months ago. According to the manual an F28 fault code can be one of about six or seven different things; including insufficient gas and ignition problems.
I called out a registered engineer and he tested for all the possible problems listed. Everything was fine. The only thing that my engineer could think of that might not be working well (even though it tested fine on firing up) was the ignition. He changed the electrode (which is a component that includes the ignition and monitoring electrode) and the boiler has been working fine since. I'm not saying that this will fix your problem if you have an F28 but I didn't see this solution listed on the net when I had the fault and it cured mine.
Best of luck
Back to top
 Alert Moderators
Bunnyman
from United Kingdom
Thanked: 1302 times
PostPosted: Sat Oct 09, 2010 3:22 pm Reply with quote
Ur 6 years to late mate check the date lol
Back to top
 Alert Moderators
DIWHY99
from United Kingdom
PostPosted: Sat Oct 09, 2010 10:38 pm Reply with quote
Thanks Bunnyman, but I can read dates icon_smile.gif (I see you've been thanked 36 times so take this as 37 icon_wink.gif) I actually wanted to reply to a later F28 thread that I saw here when I first had my problem but I couldn't find it again. So I just thought, what the heck, I might as well reply to any F28 thread I can find and anyone who searches for it will see my reply as the latest likely solution.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3532 times
PostPosted: Wed Dec 22, 2010 1:22 pm Reply with quote
You may be able to read dates but you dont seem able to read how many times Bunny has been thanked if you say its just 36.
At the time of writing thats visible to me as 61 times. But it will increment as he gets further thanks.
You only add to his thanks score by pressing the "thanks" button!
Tony
Back to top
 Alert Moderators
DIWHY99
from United Kingdom
PostPosted: Fri Dec 24, 2010 11:07 am Reply with quote
Tony
What is up with people on here? First Bunnyman has an assumptive go at me for "not" reading dates and now you lump on, totally oblivious to the fact that it was obviously just 36 WHEN I posted. Anyway, as you have both been thanked loads of times, I can only hope most of your other posts are more constructive. A happy and less pedantic holiday to you all.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vaillant Turbomax plus 828E low water pressure F28 lockout 4 5120 Sat Mar 13, 2010 2:53 pm
Compatible room stat for vaillant 828E turbomax 2 360 Mon Jul 13, 2009 9:34 pm
Vaillant 828E turbomax DHW probs 8 860 Mon Jul 13, 2009 9:06 pm
vaillant turbomax 828e racing temp and recurring S54 error 4 200 Mon Nov 22, 2010 6:22 pm
Vaillant Turbomax Pro 828E Cuts Out 8 600 Thu Jul 23, 2009 7:18 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
