DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
window cill
This topic originated from the How to page called Fitting the new window frame
Click here to return to the page called Fitting the new window frame.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
andy999
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 12:56 pm    Post Subject:
window cill
Reply with quote Thanks
how do i fit a new window cill, (internal)
mine is wood in the bathroom and rotting, i want to replace it with plastic, any tips?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 71 times
PostPosted: Tue Nov 14, 2006 6:09 pm    Post Subject:
Re: window cill
yeh, don't fit plastic sills.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Wed Nov 15, 2006 9:52 am    Post Subject:
Use Polyboard, it's pre-finished similar to worktops; it’s more expensive but looks much better than painted wood or plastic, particularly with UPVC windows. If the cill hasn’t been replaced before it’s likely to be buried in the window reveal at each end & can be tricky to get out without damaging the surrounding plaster. You need to cut through the old cill in the centre (tricky & needs care with the window still in place!) so you can lever each half of the cill up & pull it out towards the centre away from the reveal. Once you’ve got it out, make sure the reveal (under the old cill) is sound & flat, cut the new cill just slightly longer than the window opening so you can position it with each end just under the plaster. Use either an industrial strength grab adhesive or low modulus window grade silicone sealer to fix the new cill in place – don’t take too long! You can get plastic end caps to cover the exposed cut edges of the board, stick these in place. Once it’s dry repair any damage to the surrounding plaster &, if necessary, run a thin bead of white decorators caulk around edges to finish off.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
internal window cill 11 620 Tue Sep 08, 2009 8:53 am
Retain internal window cill or replace? 8 1100 Thu Feb 22, 2007 7:13 pm
Window Cill Material 2 940 Mon Feb 12, 2007 7:50 am
Fitting a Window Cill/Sill 2 3860 Wed Dec 20, 2006 11:54 pm
Warped Window Cill 2 920 Sat Aug 18, 2007 8:14 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
