DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
4 leads into a ceiling light and 1 has 2 reds and an earth?
This topic originated from the How to page called Adding a new light and switch
Click here to return to the page called Adding a new light and switch.
  View previous topic :: View next topic
Author Message
SuperEm
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 6:44 pm    Post Subject:
Reply with quote Thanks
Hello all,
Before I start let me point out that I am a complete novice at this electric thing, although I do have a fair amount of common sense...
Right then, I am trying to change a 3 way spot light fitting for a bog standard pendant. Having successfully dismantled the spot light I then tried to install the pendant. I have lots of diagrams and books...although the switch doesn't have a bit of red tape on it there is one black that looks like it has some paint on (am assuming this is the switch). I then notice that there are 4 flexes coming in through the hole - one of which has two reds and an earth. Where the hell is this one supposed to go and what does it do? Whatever I have done to it so far, I no longer have a working light...please help...
Thanks!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Tue Nov 14, 2006 7:09 pm    Post Subject:
You also have another cable.
Is there another light which switches on and off with the same switch?
__________________
I downlights
Back to top
 Alert Moderators
SuperEm
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 7:51 pm    Post Subject:
Thanks so much for your speedy reply - since its gone dark I have found that I now no longer 2 other lights upstairs...
The switch for this light only works the ceiling light - I have no idea whether there was a wall light or anything previously, but there is no evidence of one.
Is there a way to tell which of the two reds is the switched live? I have read advice about turning the power off and testing them with a meter whilst flicking the switch, but I don't really see how this works as there isn't any power...yes, I'm new to this so I'm sorry if I'm just being a bit thick.
Assuming that I just have an extra cable, can I double up on the neutral and loop connections?
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Tue Nov 14, 2006 7:57 pm    Post Subject:
I would assume the spare red and black is another feed to something else, so as you say connect it to loop and neutral.
As for the twin red, it doesn't really matter which way round you connect it, but if you look really closely you may see that the insulation on one of the red cores is solid red PVC, and the other is white PVC with a red coating.
This will allow you to match the ceiling rose and switch ends of the cable.
__________________
I downlights
Back to top
 Alert Moderators
SuperEm
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 8:33 pm    Post Subject:
thank you so much for your quick help - all is now nice and bright in our house!
thank you again!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Tue Nov 14, 2006 8:56 pm    Post Subject:
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
SuperEm
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 14, 2006 10:23 pm    Post Subject:
I even managed to get it fixed in the dark with a torch...I just glow a bit now...
thanks to all!
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Help - 3 reds and 3 blacks in my ceiling rose?! 2 260 Thu Aug 21, 2008 8:42 am
OUTSIDE LIGHT AND INFRA REDS 5 480 Thu Dec 13, 2007 8:51 am
Two Lights Two Red/Reds @ the switch 13 3660 Mon Dec 05, 2005 7:07 pm
Why do you need to null the test leads on an instrument? 15 680 Fri May 01, 2009 7:13 am
Test Leads 3 220 Sun May 03, 2009 6:11 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
