low water pressure
15 Nov 2006
my water tested at 1/2 what it should be, any suggestions??? new pipes ,pump??? :(
Where is the water coming from, where are you measuring the pressure, how are you measuring it, and in what units are you expressing the measurement of "1/2"?
water comes from a a well, measuring at the sink next to the dishwasher, by half I meant that the dishwasher manual says 1/2 gallon in 14 seconds, I get 1/4 gallon in that time
Has there been a recent change in pressure/flow?
If so, could there be a seasonal reason for this?
In any case, is the reduced pressure/flow causing a problem? For example, does the dishwasher fail to work properly?
If you need more pressure then it's temping to install a pump, but this might cause a problem because pumping water faster than the source can provide it will encourage the ingress of debris into the supply.
