DIYnot
Local | Network
   DIYnot > Forums
Local | Network
refilling central heating
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
kaptainkondom
from United Kingdom
PostPosted: Tue Nov 21, 2006 11:12 am Reply with quote
Drained the system to replace a couple of trv's its an open system with a feed n expansion tank in the loft and runs off an oil fired boiler.
after doing the trv's turned the water back on to let it refill but now only getting water out of the downstairs rads and upstairs there is little or no air coming out of the rads! left it overnight and tried again this morn still hardly any air coming out!
its abig house with a very small feed tank in the loft, tried running the boiler but it just gets too hot n shuts off!
Any Ideas???
Back to top
 Alert Moderators
gordongas
from United Kingdom
Thanked: 92 times
PostPosted: Tue Nov 21, 2006 11:26 am Reply with quote
air lock? try blowing down the expansion pipe that loops over the expansion tank
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1499 times
PostPosted: Tue Nov 21, 2006 11:30 am Reply with quote
Did the loft tank gobble lots of water down?
It is quite common for sediment to block the F&E pipe and prevent water getting down to the system. If some of the water coming out when you drained was black, you probably have quite a bit lurking in low points and a chemical clean and flush may help.
If you have a drain cock with a hose attachment, you can try filling the system through there. Filling from the bottom is a handy way or getting round air locks.
When water starts to come out of the overflow it is probably full icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Refilling a sealed central heating system 7 360 Thu Feb 20, 2014 7:54 am
refilling central heating circuit on boilermate 2000 2 780 Mon Apr 30, 2007 5:11 pm
Refilling a sealed Central Heating system 2 3240 Tue Dec 14, 2004 8:55 am
After refilling central heating system. 4 1060 Sat May 21, 2005 12:34 pm
Help - problem refilling central heating system. 9 3080 Sat Apr 16, 2005 12:43 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
