Water Pressure
Status
Not open for further replies.
27 Nov 2006
Bradford
The Water Pressure seems to come down every week, so i have to add more up to pressure 2, does any one know what is the fault
I assume you mean pressure on your central heating system.
First things to check are the radiators and pressure relief valve.
There will be a pipe on outside wall behind your boiler. Check if this has water coming from it, or has recently had water running.
Go to all of your radiators. Run your finger along the pipe and bottom of valves on each radiator to see if they are damp/wet.
I'm pretty sure you shouldn't be filling the pressure back up to 2, it should be around 1 to 1.5, what boiler do you have?
Status
