I\\\'ve been reading the posts on here, and had an electrician in (NAPIT Part P registered apparently) but just wanted to check on a couple of bits before he does the work..
I have a 40A fuse / circuit for the cooker, and plan on having a 5235kW (max) hob and 2390kW (max) single oven in the kitchen.
Adding those up and dividing by 230 = 33.15 so presume this means I\\\'m OK with the circuit, but is the control unit likely to be 30A (how can I tell)?
AFAIK he was gonna put in a junction box and put the two onto the above supply.
There is also a spare, single \\\"normal\\\" socket which I guess the cooker could go in, but it\\\'s tucked away behind a cupboard.
Any tips welcome, may get another sparky in for a 2nd opinion as he didn\\\'t fill me with total confidence.
TIA, Dan
TIA, Dan
