DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
flush ceiling fitting
This topic originated from the How to page called Connecting a flex to a bulbholder
Click here to return to the page called Connecting a flex to a bulbholder.
  View previous topic :: View next topic
Author Message
maryos
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 04, 2006 10:43 am    Post Subject:
Reply with quote Thanks
This is an earthing query: I would like to fit a flush ceiling light in my kitchen. The existing wiring is three core (red, black and bare cpc). However the light fitting (bought from Ikea; suitable for kitchen and bathroom use) has no accommodation for an earth wire. Because this is a flush fitting, the fitting itself takes place of back plate. It is made of a ceramic-type material. Does anybody have any suggestions? What do I need to do with the earth wire coming from ceiling to make sure the cable is safe?
Thank you very much!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ch427
from United Kingdom
Thanked: 3 times
PostPosted: Mon Dec 04, 2006 1:54 pm    Post Subject:
if the fitting is double insualted it doesnt require an earth,the fitting should be marked somewhere with the symbol of a square within a square,if it is then sleeve the earth and place into a connector block in the fitting
Back to top
 Alert Moderators
maryos
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 04, 2006 3:17 pm    Post Subject:
loose connector block
Thank you for your reply. I am sure that the fitting does not need an earth (I will check for this symbol). Do I just put a loose connector block into the fitting?
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 3 times
PostPosted: Mon Dec 04, 2006 4:28 pm    Post Subject:
yes,just make sure its sleeved and well insulated
Back to top
 Alert Moderators
maryos
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 04, 2006 6:06 pm    Post Subject:
Thank you very much indeed for your help - I shall do this.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Replacing ceiling rose with new flush mounting light fitting 5 1200 Wed Dec 29, 2004 1:49 pm
fitting flush ceiling downlighters in concrete ceiling!! 5 1320 Tue Mar 02, 2004 11:48 am
ceiling rose flush fitting light 2 660 Mon Oct 24, 2005 11:12 pm
fitting flush lights in concrete 4 1620 Mon May 15, 2006 3:15 pm
1930s walls, flush fitting electrial boxes 11 700 Mon Jan 29, 2007 11:33 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
