DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Ravenheat csi 120 low nox problems (Help)
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
gman58
from United Kingdom
PostPosted: Sun Dec 10, 2006 8:14 pm Reply with quote
I had a Ravenheat csi 120 low nox condensing combi fitted about 2 months ago. All was going well until last night it cut out with a #14 fault (flame simulation) after resetting it was working ok again. Then tonight it cut out altogether, after inspecting the PCB the main fuse ( F1) had blown so i replaced it. But now it wont fire up, the pump and fan are running but its not firing at all. Any help would be greatly apreciated!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Sun Dec 10, 2006 8:27 pm Reply with quote
I really dont see why you are fiddling with your boiler when you should be calling the installer who may need to liase with the manufacturere under the warranty.
Did the Installer complete the benchmark Certificate and notify CORGI who will have written to you to confirm he is registered?
Or are you experiencing the problems associated with an installation by a non registered installer?
Tony Glazier
Back to top
 Alert Moderators
scatmanjohn
from Brazil
Thanked: 158 times
PostPosted: Sun Dec 10, 2006 8:32 pm Reply with quote
Back to top
 Alert Moderators
gman58
from United Kingdom
PostPosted: Sun Dec 10, 2006 8:46 pm Reply with quote
Unfortunatly being on minimum wage wife and family and not having 2p to rub together i had to get it fitted by a none registered fitter. I struggled to get the boiler and now having problems. I just thought it may be a simple fix so had a look myself.
Back to top
 Alert Moderators
scatmanjohn
from Brazil
Thanked: 158 times
PostPosted: Sun Dec 10, 2006 9:08 pm Reply with quote
Sorry to hear about you skint situation but getting a gas appliance fit by an unregistered installer is playing with fire.
I doubt that anyone will offer any advice on how to get a boiler going that has been installed by a unregistered gas installer.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Sun Dec 10, 2006 9:44 pm Reply with quote
I would be prepared to help but just dont know what to suggest. It might be a manufacturers fault but much more likely in the circumstances to be due to bad installation.
To all those reading this please realise the problems you can face by using an unregistered installer. Firstly, obviously they are not qualified, have little experience and will not be able to fault find. Secondly, several manufacturers like Ravenheat do not offer any guarantee cover unless their boilers are properly fitted by a CORGI and the Benchmark is completed.
When I go to a boiler on behalf of a manufacturer, if the problem is as a result of faulty installation it becomes a chargeable call at our standard fee of 84.
These kind of problems can often end up costing more than the extra of using a CORGI in the first place. Another advantage of using a CORGI is that if he does not do the gas side properly then CORGI will serve a "Defects Notice" requiring him do complete the job properly at his own cost. When he has not bothered to properly size the gas supply pipe that can be quite costly for him! To RGIs maximum pressure loss 1 mB at full boiler power!
Tony Glazier
Back to top
 Alert Moderators
gman58
from United Kingdom
PostPosted: Sun Dec 10, 2006 10:15 pm Reply with quote
Will probably have to wait to get someone in to have a look. Thanks anyway guys, i appreciate the advice.
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Sun Dec 10, 2006 10:21 pm Reply with quote
you should have talked to Mr Blairs cronies they would have paid for a boiler to be fitted for you under the warmfront thingamajig but only if you were genuine, if not then you are now reaping the reward of thinking you are smarter than the average bear arent you
good luck in getting someone thick enough to have a look, and if you do they should be filling out a RIDDOR report to the H&S and reporting you and the cowboy moron who installed it for you
no such thing as a free lunch is there
Back to top
 Alert Moderators
Slugbabydotcom
from United Kingdom
Thanked: 83 times
PostPosted: Mon Dec 11, 2006 3:38 am Reply with quote
I'm sure I have had the same problem before and the culprit was actually the ch 'clip on' thermistor. It did seem illogical as the code for this was #12.
I remember calling Ravenheat and asking them to translate what 'flame simulation on the flame control unit' actually meant
No guarantees on that but given your financial situation it could be worth trying.
You may have a bit of fun trying to get the right part as well. It should be a green clip on thermistor. The part number I have is 0007TER05005/0 but check your instruction book. Try calling Ravenheat for the part. If you are nice about it and explain your situation you could be lucky and get one for free.
I do remember that there was a leak on it as well. The large nut on the pipe leading to the gas valve was not tightened up properly at the factory.
Come on lads show a bit of compassion. Its the less well off that are more likely to fall victim to cowboy installers. To find themselves in this situation is just another kick in the teeth.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3565 times
PostPosted: Mon Dec 11, 2006 12:53 pm Reply with quote
I usually find that the less well off usually employ a CORGI because they want to ensure their hard earned money is not wasted.
Its the well off who seem to want to use non registered people to save them money to make them even better off.
There are several schemes like Warmfront which can help people on low incomes but the people who need it most often dont know about them.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Ravenheat problems - can anyone help? 16 7780 Sat Nov 26, 2005 8:37 am
Ravenheat Combi problems 9 1280 Fri Dec 09, 2005 3:57 pm
Ravenheat csi 85 problems 12 560 Sun Nov 16, 2008 2:58 pm
Ravenheat csi85 real problems with hot water and rad temp 5 60 Mon Dec 17, 2012 4:01 pm
Ravenheat RSF 84E (T) Boiler problems 3 1380 Mon Jun 20, 2005 9:54 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
