Baxi (2) Solo 50PF
17 Dec 2006
Avon
Any advice please, The PCB on my baxi buzzes for approx 5 seconds when turned on. This only happens when calling for central heating and the Draytom mid position 3 way valve is moving from the Hot Water to the Central Heating position. I have so far replaced the PCB and Drayton valve but the problem remains.
This is caused by the relay opening and shutting rapidly (chattering) due to a low voltage supply from the diverter, to solve the problem, you need a suppresor fitted across the boiler neutral and switched live.
Err ... sorry, what low voltage supply from the diverter valve would that be ?
From memory, as the valve moves it sends out aprox 85 - 90v ac, (measured at the boiler switched live) enough to upset the relay but not enough to start the boiler sequence, only trying to help!
Ignore him mate ,,,,he is the resident smart ass
Where's the REAL smart ass answer then, don't see any one else offering advice, only criticism.
Whatever - I'm still waiting for an answer
Poxi has given a totally useless, meaningless reply - no use to man nor beast
He also has a clue and a healthy disrespect for fitters
I'm making a point of being restrained
of course ... I could go back to my normal agressive self - your choice
and I will lay into you at every opportunity, of course
That wasn't aimed at you baxpoti , but Mr smart arse who tries to belittle anyone if he thinks he can get away with it.
He is a bully. just ignore him, he will go and try his little games on someone else.
From reading your previous posts its quite clear that you do have a clue about electronics on boilers.
But you are clearly "clueless" when it comes to respecting people.
You make it sound like we should be grateful
Well if its my choice i would prefer it if you wasn't agrressive.
Please don't, I'll do anything you ask :rolleyes:
that raden is such a t*at... still lives at home with his mum and soldering iron..
Fraid not - however, just the sort of post I'd expect from an uninformed retatrd
ah well, back to CORGI baiting then
I had another in today with a fan "which doesn't work"
tested it, it workrd fine
Allmaecht - there are some clueless fitters out there
