DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
buzzing fuse board
This topic originated from the How to page called Identifying a faulty circuit
Click here to return to the page called Identifying a faulty circuit.
  View previous topic :: View next topic
Author Message
Kiryu
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 19, 2006 8:18 am    Post Subject:
buzzing fuse board
Reply with quote Thanks
Hi all, does anyone know why my fuseboard makes a loud buzzing noise when my electric fire, kettle & spindryer are running at the same time? : icon_eek.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
THRIPSTER
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 19, 2006 9:22 am    Post Subject:
Wasp's nest behind it?
Back to top
 Alert Moderators
miajanjua
from United Kingdom
Thanked: 0 times
PostPosted: Tue Dec 19, 2006 9:30 am    Post Subject:
Re: buzzing fuse board
Its possible for a hum to be heard from the CU, but most
of the time it is inaudible.
This happens due to the magnetic effect created by the High
currents passing through the conductors interacting with
magnetic field of other conductors in the close vicinity
and the earths magnetic field to a small extent.
Further if these conductors are not physically
restrained and are touching other conductors/CU sides
then it is possible for a louder hum to be heard as the
cable vibrate when under high load.
__________________
Moses took his tablets
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Dec 19, 2006 12:58 pm    Post Subject:
Has it really got fuses in it? With bits of fusewire? Then it is likely to be very old. There may be something loose inside if you can actually hear it.
Is it brown?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Dec 20, 2006 9:06 pm    Post Subject:
That's a bit personal, John...
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Wed Dec 20, 2006 9:11 pm    Post Subject:
sure its not the meter you can hear? these always hum / buzz / clank / whirr.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Wed Dec 20, 2006 11:12 pm    Post Subject:
[quote="miajanjua
.[/quote]
Its called magnetostriction and is usually only audible in transformers or large switchpanels.
I would advise having the CU checked to be on the safe side
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Wed Dec 20, 2006 11:15 pm    Post Subject:
Yes have it checked. Could be a loose connection...
TTC
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Dec 20, 2006 11:45 pm    Post Subject:
Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm.
__________________
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 19 times
PostPosted: Wed Dec 20, 2006 11:55 pm    Post Subject:
miajanjua wrote:
ricicle wrote:
[quote="miajanjua
mag·ne·to·stric·tion
n.
Deformation of a ferromagnetic material subjected to a magnetic field
There is no ferromagnetic material in all CU's that I have worked on and no transformers in them either!!!
It may be a loose wire, But then why the humming/buzzing Noise?
What's the loose wire to do with the noise? what is the effect causing the noise?[/quote]
Yeah went off on a bit of a tangent there.If there is some loose connection in there be it a wire or fuseholder/mcb then there could be some vibration in there as the circuits are reacting with each other
Back to top
 Alert Moderators
nozspark
from United Kingdom
Thanked: 3 times
PostPosted: Thu Dec 21, 2006 5:22 pm    Post Subject:
How's about a bell transformer adjacent to the CU!!
Back to top
 Alert Moderators
RMS
from United Kingdom
Thanked: 1 time
PostPosted: Thu Dec 21, 2006 6:31 pm    Post Subject:
wylex boards use to have a din rail in the board to mount door bell transformers at the end. Thats the only buzzing i've come across in a domestic consumer unit.
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 57 times
PostPosted: Thu Dec 21, 2006 6:36 pm    Post Subject:
Are you sure that the buzzing isn't coming from the meter itself. I've heard meters hum when there is a high drain. I'm not sure what's inside a meter but something turns that wheel round.
Back to top
 Alert Moderators
TANNERS
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 9:32 pm    Post Subject:
has your mrs hidden her special toys in it
Back to top
 Alert Moderators
DESL
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 11:00 pm    Post Subject:
I had this recently when I'd installed a new CU - heard a buzzing from cupboard - it was the new electronic meter
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fuse Board and Appliances Buzzing 21 820 Wed Jul 09, 2008 1:15 pm
light buzzing and flickering 3 360 Wed Oct 17, 2007 11:52 am
dimmer switch buzzing 3 620 Wed Oct 17, 2007 5:40 pm
Buzzing Light No Power - How? 13 620 Sat Oct 27, 2007 10:09 pm
Buzzing Bulbs 3 183 Fri Jan 25, 2008 9:10 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
