DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
radiator leak
This topic originated from the How to page called Fixing a leaking radiator
Click here to return to the page called Fixing a leaking radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jooles
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 22, 2006 9:19 pm    Post Subject:
radiator leak
Reply with quote Thanks
Hi my bathroom radiator leaked from the valve and was fixed by replacing it, now 4 days later my living room one is leaking. The water has to be turned off cos the leak won't stop so no hot water or heating. Can the two leaks be linked somehow or is it just coincidence? thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Dec 22, 2006 9:59 pm    Post Subject:
It's very often because they're equally old, and are wearing out at about the same time. I am guessing that they are weeping past the spindle. Sometimes if you screw them all the way out (or all the way in) it will stop dripping.
If you replace them yourself, this could be a good opportunity to buy a dozen new lockshields (some with integral drain-off) and a dozen new TRVs, and renew the lot.
That way you only have to drain down and get your tools out once every ten years or so. Summer is the best time to do it, though, when you won't mind having the boiler off for a weekend. Give it a chemical clean, and refill with inhibitor.
Unless the drip is significant (it will ruin your carpet) you might consider putting a pan under it until Christmas is out of the way.
p.s. Do you have a Combi boiler? Is the pressure too high? (this is often because the Filling Loop has been left connected).
If you system is topped up by a feed and expansion tank in the loft, this does not apply.
Back to top
 Alert Moderators
weareleeds
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 23, 2006 4:36 pm    Post Subject:
If you have a sealed system )ie combi) i bet that you have old valves which don't meet bs2767 so as previously posted change them all but insist on good quality valves that will cope with at least 3 bar pressure
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 10 times
PostPosted: Sat Dec 23, 2006 4:47 pm    Post Subject:
can you not repack the gland?
__________________
no to pointless signatures
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Thermostatic Radiator valve leak... Bank hol weekend.. 11 240 Mon Aug 31, 2009 12:00 am
LEAK FROM RADIATOR 5 340 Tue Dec 11, 2007 10:02 am
Specific Radiator Leak Problem 3 580 Fri Apr 28, 2006 8:19 am
yorkshire valve radiator leak 4 280 Wed Jul 08, 2009 12:35 pm
How do you track down a leak in underfloor radiator piping? 13 640 Mon Jun 22, 2009 12:25 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
