DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
outdoor cable woes
This topic originated from the How to page called Choosing the correct size cable
Click here to return to the page called Choosing the correct size cable.
Goto page 1, 2, 3, 4, 5  Next
  View previous topic :: View next topic
Author Message
tritonr1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 4:38 pm    Post Subject:
outdoor cable woes
Reply with quote Thanks
Hi, need some help on what cable to use to power my Garage ?? well to cut a long story short my garage was powered when we moved into our house a few years ago but over the last couple of days the RCD to the garage keeps tripping out, the cable is armoured but it only looks like 4 core 2.5mm , my garage has a 3kw heater keeping my pride and joy dry (R1) 2 double plug sockets, 2 strip light and 6 outdoor lights (60w bulbs)..cant think of anything else so if ive missed any vital info that you need to know please ask.
regrads dave
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Dec 29, 2006 4:40 pm    Post Subject:
its unlikely to be the swa at fault.
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
davelx
from United Kingdom
Thanked: 6 times
PostPosted: Fri Dec 29, 2006 4:45 pm    Post Subject:
Where is the RCD that is tripping out? Type and rating?
Is there a CU in the garage? What is in it? Suppling what circuits?
How is the feed connected back at the main CU?
What is providing overcurrent protection to the garage feed at the consumer unit in the house - MCB, RCBO? - what type and rating of device (picture if you are not sure).
What is the length of the cable run from Cu to Garage?
What is the earthing system?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Dec 29, 2006 4:49 pm    Post Subject:
true, but its still unlikely to be the cable, also there is no rcd in the garage, since the op said..........."RCD to the garage
__________________
Forum = Opinions
Back to top
 Alert Moderators
davelx
from United Kingdom
Thanked: 6 times
PostPosted: Fri Dec 29, 2006 5:00 pm    Post Subject:
Maybe - I always like to have the full picture. Not everyone uses language in the same way and I've seen people say "to" when they mean "in" more than once.
Back to top
 Alert Moderators
tritonr1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 5:21 pm    Post Subject:
davelx i will answer the question in order of being asked to stop any confusion
the rcd thats tripping is in the house (see pic below)
yes there is a cu in the garage main switch 63a, sockets 20a, lights 6a plus a 6a not used
cable run is approx 10m
only earth that i can see is into the cu in the house
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Dec 29, 2006 5:25 pm    Post Subject:
It is more likely to be something damp in the garage. Try unplugging everything and see if that fixes it. Then plug them back in one at a time.
If not, turn off the main switch of the garage CU. If it still trips it is something between the house CU and the garage CU (and there's not much there except the cable.)
If you have any external junction boxes,sockets, switches or lamps, examine them for water ingress. Water can also run down the cable where it enters the building unless it has a drip loop.
Edited: In your pic it is the MCB that looks tripped, not the RCD. Please elucidate.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Fri Dec 29, 2006 5:26 pm    Post Subject:
i still say its not the swa cable. they not bullet proof but they are designed to take stick, burried
leave the garage cu off, everything unplugged, lamps removed and see does the house rcd trip
__________________
Forum = Opinions
Back to top
 Alert Moderators
tritonr1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 5:38 pm    Post Subject:
cheers for the replys guys, i have done as instructed turned the main cu off in the garage but the rcd still trips in the house....i know you say its not the swa cable but i have had the whole area where the cable is block paved in november....personally i was putting it down to the cable only being 2.5 and thought it would me more suited to 4mm...but then again im no expert (thats why im here asking)
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Dec 29, 2006 5:41 pm    Post Subject:
Does the SWA run straight into the CU at each end, or is there a metal adaptable box? If so, where is it?
Can we have a pic of the SWA coming through the walls at each end please?
Back to top
 Alert Moderators
momo32
from Ireland
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 5:44 pm    Post Subject:
Just to clarify: it is the RCD in the house CU tripping? Not the MCB beside it in your picture labelled 'garage'?
Back to top
 Alert Moderators
tritonr1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 5:49 pm    Post Subject:
ahh yes well the rcd is also used for the shower.... hence the mcb being switched off
yes the swa runs straight into each cu...cant take photos of the cables without causing damage to either the house or garage
Back to top
 Alert Moderators
momo32
from Ireland
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 5:53 pm    Post Subject:
So is it at all possible that it's actually the shower at fault??
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Dec 29, 2006 5:55 pm    Post Subject:
And I was interested in seeing if the SWA ran into the CUs in such a way that water could run down the cable and into the casing.
Back to top
 Alert Moderators
tritonr1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 29, 2006 5:56 pm    Post Subject:
its not the shower as that doesnt trip the rcd....if i switch the mcb on to the garage the rcd will trip
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 5
Jump to:
Dimmer and downlight woes, can anyone help? 3 240 Sun Apr 20, 2008 9:23 am
Shower Woes... keeps tripping trip switch 17 760 Tue Dec 16, 2008 2:47 pm
dimmer switch woes 12 340 Thu May 14, 2009 11:21 am
Smoke Alarm woes 2 300 Sun Nov 18, 2007 11:27 am
Electric woes with a new 2 way light switch 5 400 Fri Jul 04, 2008 5:19 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
