DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
cable routing in skirting
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
  View previous topic :: View next topic
Author Message
russell58
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 30, 2006 2:09 pm    Post Subject:
Reply with quote Thanks
I want to get speaker cable and telephone cables hidden behind skirting board. Concrete floor below so underfloor not an option. Any advice on what products to use of what to look out for.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sat Dec 30, 2006 2:14 pm    Post Subject:
Do you have dual face skirtings?
Back to top
 Alert Moderators
russell58
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 30, 2006 2:16 pm    Post Subject:
Don't know what dual face skirtings are - I don't think so.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Dec 30, 2006 2:17 pm    Post Subject:
One way of doing it:
Remove the skirting and fasten timber battens to the wall. One exactly aligned to the top of the skirting and one about 18mm above the floor.
If your wall is plastered brick or block you can cut back the plaster to the line of the battens. Fill neatly the joint between the top batten and the plaster.
This gives you a gap between the battens to run cables such as speakers, phone, broadband, co-ax. You may need to use screened cables to prevent them interfering with each other.
You must not run power cables in this way (unless protected with an earthed metal barrier) in case someone put a nail through them, and power cables have to be segregated from anything else.
Fasten the batten securely with screws and plugs. The skirting need only be lightly fastened to the battens with countersunk screws which you can decorate over if you like. As they are away from eye level you can also just paint the screw heads but leave them accessible. This makes it easier to remove them for future cabling, and also makes decorating a lot easier.
Back to top
 Alert Moderators
momo32
from Ireland
Thanked: 0 times
PostPosted: Sat Dec 30, 2006 2:20 pm    Post Subject:
A more expensive though similar method is to use skirtings with channels routed in them - I think Homebase do them. They look good and claim to allow plenty of space for (low voltage/signal only!) cables.
edited for spelling.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 30, 2006 5:56 pm    Post Subject:
If you have a router (or know someone with a router) you can make the channel yourself using any standard skirting and a straight cutting bit.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sat Dec 30, 2006 7:17 pm    Post Subject:
If you remove a section of skirting the dual face type have a moulding on both faces so that you can have a choice of finishes( shapes).With this type there is normally enough room between the bottom of the moulding & the wall to run small cables. In any case if your plastering has been done properly you should have a gap between the floor & the start of the plaster.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
routing behind skirting board 36 2420 Tue Nov 15, 2005 9:35 pm
Cable behind skirting board 7 1720 Fri Feb 02, 2007 12:29 pm
Wiring behind skirting boards???? 7 860 Mon Jun 26, 2006 1:53 pm
Switch above skirting 2 220 Sun Sep 10, 2006 5:55 pm
Sockets on skirting boards 30 2460 Tue Jul 18, 2006 9:36 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
