please can someone help, my washing machine gets halfway through it's programme then stops and flashes lights alternately between start and spin indicating some sort of problem, also the fab conditioner is not being taken.
Hi
Unfortunately I don't have a multimeter at the moment, but I can get hold of one and I'll be back in touch when I have it, if that's Ok
Cheers
Robin
Please check your pump impeller for any play as this can prevent the pump from emptying the washer causing it to time out and start the flashing light - fault sequence. There should be very very little to no sideways/updown play.
