Halogen light transformer reqd (fits in ceiling rose)
10 Jan 2006
It's manufactured by Anchorn, model number is AET-3202CT. 240v to 12vdc and it looks (and size) a bit like a ceiling rose with a 12 mm hole through the centre for the cable. It fits inside the cover of a ceiling light.
Anyone seen anything like this or know where I can get one?
What is the VA rating of the transformer, or how many lamps are there on the fitting and what wattage is each lamp?
It is unlikely you will be able to get an identicle replacement transformer without approaching the fitting manufacturer direct, but we may be able to reccomend one that wll do the job and mount either direct into the fitting, or the ceiling void above.
Can you provide us with dimensions of the top part of the fitting where the existing TX is mounted?
Just went on google the SECOND result threw this up.
http://www.chinamedia.org/hsinchang/showroom_EN_.gmwl
11th one down
That's the very transformer - doubt if they'd be interested in sending me one from China :rolleyes:
Any ideas? would you have anything similar?
Ta
