DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Wiring unearthed cooker hood
This topic originated from the How to page called Installing a cooker hood
Click here to return to the page called Installing a cooker hood.
  View previous topic :: View next topic
Author Message
lyntwyn
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 04, 2007 1:28 pm    Post Subject:
Reply with quote Thanks
I have purchased a new stainless steel cooker hood. Unlike my existing canopy type which plugs into normal 13 amp outlet (within the cooker socket), this hood has only a two core cable and bears the double insulated sign.The manual says to "connect the cord to a socket or ominpolar switch which must have a minimum contact opening of 3mm".
Will it be enough to connect a 13 amp plug using only the L & N connections ( as obviously there is no earth cable) with a 3 amp fuse and use the original socket, or will I have to install a new omnipolar (what's that?) fcu? If so, can I run a cable from the original socket to the FCU?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Thu Jan 04, 2007 1:50 pm    Post Subject:
Cooker hoods are one place I do NOT trust "double insulation" where the exposed surface is metal.
What ever the instructions say I would earth the frame.
A cold hood and a pan of boiling water on the hob and condensation inside the hood may over come the double insulation.
Bernard
Sharnbrook
Back to top
 Alert Moderators
lyntwyn
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 07, 2007 2:19 pm    Post Subject:
I understand your reservations, which up till now I have shared. However, it appears to me (following a visit to Currys & B&Q)that the majority of hoods are now double insulated, and carry the instruction "this appliance MUST NOT be earthed". This includes top brand names such as Miele etc. Therefore I am now happy to accept the principle despite it being rather alien to me. I am just concerned about how to wire it up properly.
I have removed a hob unit which will not be replaced so I have a spare cooker power point on a radial 32a circuit. Can I use this to wire to a 3a FCU next to the hood, into which the hood will be directly fed? Should (must) I use the existing cooker cable to wire in to FCU?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Earthing an unearthed kitchen 7 520 Tue Dec 19, 2006 9:25 am
Unearthed lighting circuits 3 460 Wed Mar 17, 2004 1:31 pm
Advice on CU change where switch drops are unearthed 22 920 Mon Jun 30, 2008 7:41 pm
Cooker hood wiring 3 4640 Mon Jul 11, 2005 3:01 pm
Wiring a cooker hood 2 760 Wed Oct 03, 2007 12:12 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
