DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
air in radiators
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
fju
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 10, 2007 12:20 pm    Post Subject:
air in radiators
Reply with quote Thanks
I wonder if you could help.
Our bathroom radiator upstairs has been collecting air for the last few months. The air seems to collect when the heating turns off so that the next time it comes on it requires bleeding. I\\\'ve been regularly bleeding the radiator every few days and this solves the problem for a few days until the air recollects.
Over the last two days however I\\\'ve noticed that all the upstairs radiators and one radiator downstairs has air in it. I therefore bled all the radiators and they worked fine for one day but have now refilled with air. I can\\\'t keep on bleeding all the radiators every other day! Any suggestions would be greatly appreciated
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Thu Jan 11, 2007 2:44 am    Post Subject:
How would you feel about revealing some of the dark secrets about the rest of your system?
See the sticky topic at the top of P&CH if you need hints.
Back to top
 Alert Moderators
fju
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 17, 2007 7:37 pm    Post Subject:
We have a Halstead Best 50 boiler with 5 radiators downstairs and 4 upstairs. Interestingly over the last week only the bathroom radiator is refilling with air as was the problem initially. The others seem to be OK at the moment. I've heard a term 'pumping over'. What does this mean?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 6 times
PostPosted: Wed Jan 17, 2007 10:10 pm    Post Subject:
'Pumping over' is a colloquial term used in the context of open vented heating systems. It means that water is emerging from the F&E vent pipe.
The condition indicates that the pump is set too high, or that there is a blockage in the pumped circuit (resulting from corrosion), or both.
The remedy usually involves cleaning/flushing out the system, and possibly some/all radiators, to remove sludge and debris.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Radiators hot upstairs but cold downstairs 4 660 Mon Feb 11, 2008 6:48 pm
How many radiators? 6 220 Sat Feb 09, 2008 12:23 am
Where to buy radiators (not Screwfix it seems)? 8 580 Tue Feb 05, 2008 5:42 pm
Can U bleed radiators from combi boiler systems? 2 680 Wed Feb 13, 2008 10:30 am
Very noisy radiators - bubbling sounds 2 380 Wed Feb 13, 2008 11:49 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
