DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hotpoint WMA 30 drain problem
This topic originated from the How to page called Washing machine troubleshooting
Click here to return to the page called Washing machine troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
Horace
from United Kingdom
PostPosted: Fri Jan 19, 2007 6:33 pm Reply with quote
My hotpoint wma30 sometimes will not drain, I've had the pump off and cleaned it, but the problem still persists. A temporary solution I've found is that if I fiddle with the drain hose, remove it from it's clips and lower it and then reclip it the machine will then carry on and complete the cycle as normal. The hose does not go any higher than the top of the machine, it just doesn't seem to have enough power to start the initial drain process. Any idea's anyone?
Back to top
 Alert Moderators
whatajob
from United Kingdom
PostPosted: Fri Jan 19, 2007 11:11 pm Reply with quote
It is most likely the pump at fault. If the pump housing and coin trap are all clear of debris, then you have an intermittent pump. I've encountered several over the years, so just change it.
Back to top
 Alert Moderators
james171271
from United Kingdom
PostPosted: Mon Jan 29, 2007 11:46 am Reply with quote
there could be another explanation on hotpoints at the bottom of the drum there is another filter unplug from mains and remove the back panel the main black pipe that is attatched to the bottom of the drum by a jubilee clip unscrew this and inside there is a plastic ball and a filter often this filter gets blocked up and reduces flow to pump hotpoint would charge you call out for this 80+ any help you need or step by step instructions please email me i will be more than happy to help
______________________________
Lynda, moderator
The op can not email you as your email address is not in your profile (please also note forum rule 7)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
hotpoint wma 10 drain problem 18 3140 Fri Jan 05, 2007 1:54 am
Problem with the drain/outflow from Miele Washer dryer 3 1040 Tue Dec 02, 2008 9:59 pm
Common drain problem ( pump ) 8 1340 Thu Nov 15, 2007 4:39 pm
Indesit W161 Drain/Spin Problem 2 3360 Sun Nov 27, 2005 2:46 pm
Zanussi dishwasher drain hose problem 3 1820 Mon Aug 10, 2009 9:57 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
