DIYnot
Local | Network
   DIYnot > Forums
Local | Network
fixing small leak on solder joint
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
DJM
from United Kingdom
Thanked: 4 times
PostPosted: Mon Jan 22, 2007 11:43 am Reply with quote
I have a main water feed pipe to the electric shower that has a very small weep on a solder joint. It produces a small drip about every hour or so.
The joint is at the end of an S-curved pipe and appears to have been flared by the original plumber to allow the next pipe to join on without a connector, then soldered. This was fitted before we bought the house and I would extimate it is 15 years old.
I therefore can't simply replace the fitting, or the run easily, so is there anyway I can seal the joint?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1511 times
PostPosted: Mon Jan 22, 2007 11:54 am Reply with quote
There is a product called Fernox LSX that is a sort of rubberery paste, it sets quickly in the presence of water. It can be smeared over and into the gap. It might cure your problem. It will also fix itself securely to your skin and fingernails.
The problem you will have is that any water pressure in the pipe will prevent you pushing it into the hole. So turn off the supply to the shower and open the tap to relieve pressure. Clean out the old joint with your wife's toothbrush as it may be partially filled with old flux.
You had better start thinking about cutting out the faulty part and inserting a compresssion piece. It is very difficult to re-solder pipes once they are wet.
Back to top
 Alert Moderators
DJM
from United Kingdom
Thanked: 4 times
PostPosted: Mon Jan 22, 2007 12:55 pm Reply with quote
JohnD you are obviously a man of many talents assuming you are the same JohnD from teh electrical forum. Thnaks.
I have seen Loctite Repair Express Power Putty which claims to seal pipes permanantly. Is this any good.
It's just a real mare to get back to a straight piece of pipe to hack out the single weeping joint.
Back to top
The following user says thank you to DJM for this useful post:
JohnD (26 Sep 2013)
 Alert Moderators
Agile
from United Kingdom
Thanked: 3610 times
PostPosted: Mon Jan 22, 2007 1:04 pm Reply with quote
If you can drain the pipe there is a little trick I tell trainees.
If you use electrical solder this has cores of flux within the solder and the flux is particularly good and will usually enable a repair to be made to a badly soldered plumbing fitting without taking it apart.
It should not be used on pipes carying potable water so it should not be used on your shower fitting if its mains fed.
Thats the latest law but as many houses are supplied by 10 m of lead pipe its come a bit late for many installations.
Tony
Back to top
 Alert Moderators
DJM
from United Kingdom
Thanked: 4 times
PostPosted: Mon Jan 22, 2007 5:45 pm Reply with quote
Unfortunately it is a mains fed shower so I'll have to pass on the electrical solder idea. Thanks anyway.
I guess I can get some Loctite and see if it works, if not I am no worse off
Back to top
 Alert Moderators
lupage80
from United Kingdom
PostPosted: Thu Sep 26, 2013 4:55 pm Reply with quote
DJM - I know this post was a few years ago but did it the loctite/LSD work? How did you go about fixing? I have a similar problem with minute weep on a pipe.
Back to top
 Alert Moderators
Madrab
from United Kingdom
Thanked: 264 times
PostPosted: Thu Sep 26, 2013 5:49 pm Reply with quote
If it's a temporary repair you want then pipe repair putty will do the job, Evo stick do some I think but a proper soldered/compression fix is the only long term solution.
Back to top
 Alert Moderators
kidgreen61
from United Kingdom
Thanked: 201 times
PostPosted: Thu Sep 26, 2013 7:40 pm Reply with quote
FFS just do it properly, cut the offending piece out, and replace it.
Back to top
 Alert Moderators
dcawkwell
from United Kingdom
Thanked: 513 times
PostPosted: Thu Sep 26, 2013 8:38 pm Reply with quote
Easy. If you can vacuum out the water from the pipe.
Paint a good bit of flux onto the joint and using a hot torch brazing torch
heat it up and then apply a goodly amount of solder.
Finish by brushing with more flux after you remove the heat.
That usually cures a leaky joint.
Failing that it's a case of replacing the joint.
Back to top
The following user says thank you to dcawkwell for this useful post:
lupage80 (27 Sep 2013)
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Small leak / weep from radiator solder joint 2 80 Wed May 15, 2013 10:45 am
Solder Joint Plumbing - How Hard It It In Reality??? 43 2120 Fri Oct 09, 2009 6:48 am
Testing a solder joint for leaks .... 3 480 Fri Aug 08, 2008 9:10 pm
Compression or solder joint on gas line 7 1300 Thu Oct 25, 2007 10:30 am
how to remove solder to fit different joint, advice please 4 140 Wed Jul 20, 2011 7:52 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
