mgclarke
Joined: 22 Jan 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Mon Jan 22, 2007 12:32 pm Post Subject: Cellar Extractor Fan Query |
My cellar is ever so slightly damp and I have been advised that I should look to fit an extractor fan in there to help this problem. There is an existing air brick in the wall, but I am after some advice on what would be best to fit in there? Would a kitchen or bathroom extractor fan do the job?
Many thanks for any help and info. |
dingbat
Joined: 29 Sep 2003 Posts: 2205 Location: West Midlands, United Kingdom Thanked: 0 times
Posted: Mon Jan 22, 2007 12:45 pm Post Subject: |
How big? How damp? A dehumidifier may be the answer. Alternatively, a large extractor fan with a humidistat may do the job, but you need to quantify what volume of air you need to shift |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Mon Jan 22, 2007 1:16 pm Post Subject: |
Cellars are (almost) always damp as they are usually in old houses with no dpc and the walls are in contact with the earth.
You could save some money by opening up air bricks on both/all sides of the building so that you get a through flow of air (there is almost always a pressure difference on the different sides of a house).
If you ever want to put down a new cellar floor you can dig out the old one and lay new with DPC, but the walls will never be dry.
Underground rooms are now built assuming that water will get in somehow, and have drainage channels and a pumped sump. |
mgclarke
Posted: Mon Jan 22, 2007 1:43 pm Post Subject: |
Thank you for the info so far. The cellar is roughly 8 metres by 8 metres and it is not damp as such but items that are left in there are getting slight mold marks on them. |
DIYJob
Joined: 02 Jun 2008 Posts: 1 Location: Isle of Wight, United Kingdom Thanked: 0 times
Posted: Mon Jun 02, 2008 9:11 am Post Subject: damp cellar |
I have a similar problem with my cellar.
Pls. could you tell me how you solved this problem.
Many thanks
DIYJob |
