DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer switch wiring
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
ggevans
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 23, 2007 9:30 pm    Post Subject:
Reply with quote Thanks
I want to wire a simple tungsten household bulb with a dimmer i.e. 3-pin 240v/3A plug - cable - dimmer - cable - bulb holder with bulb. I have a single way dimmer with two connectors. I have connected live to plug, live to dimmer connector, live from other dimmer connection and on to bulb holder. Neutral connected to plug and from plug to bulb holder. When I switch on at the mains the bulb lights but with the dimmer switched \\\'off\\\'. When I switch the dimmer \\\'on\\\' and rotate the switch nothing happens but the bulb stays on. Do I simply have a faulty dimmer or have I made a mistake? Thanks for any help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Jan 23, 2007 9:41 pm    Post Subject:
from what you have typed it sonds right (but no earth, no back box for dimmer, batten holder not fixed) eirther its a naff dimmer or a dimmer thats naff, in that it may be over rated for the lamp, some dimmers have a MINIMUM as well as Maximum load
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
ggevans
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 23, 2007 10:00 pm    Post Subject:
Sorry, I didn't make it clear what I was trying to achieve. The dimmer has a back box but no earth point - simple, cheap rotary dimmer from Homebase. I want to have a temporary setup for some photography. Hence I have a basic plug to dimmer to bulb setup all mounted on a board but with no potential for an earth connection. I think the dimmer is blown so will return it to the store first. Thanks for the reply
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Jan 23, 2007 10:02 pm    Post Subject:
__________________
Forum = Opinions
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Jan 23, 2007 10:12 pm    Post Subject:
I dont think i need to ask, but how did you wire the dimmer? icon_rolleyes.gif
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Tue Jan 23, 2007 10:13 pm    Post Subject:
read hist first post again, he does say
__________________
Forum = Opinions
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Jan 23, 2007 10:17 pm    Post Subject:
Back to top
 Alert Moderators
ggevans
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 24, 2007 2:51 pm    Post Subject:
Re: Dimmer switch wiring
Sorry - no bangs, sparks or anything else enjoyable just the bulb lit and stayed lit until power off at the socket. Will try another dimmer from Homebase later - I may even be persuaded to spen an extra pound on a supposedly better one!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Wed Jan 24, 2007 9:10 pm    Post Subject:
Oh, they're better, trust us on that one. Electrics is an area in which things are expensive for a reason - if a brand were needlessly expensive, electricians wouldn't buy them, as it would batter their margins, and the manufacturer would go out of business.
Usually if you find 2 dimmer switches side by side, one £5 dearer than the other, there's a reason why. Quality. One will have a built in fuse to stop it frying on bulb failure. One will have a better dimmer mechanism. One will have better quality electronics inside. One will last much longer. icon_wink.gif Guess which the electrician will give you? The better one. Because then he wont be called out to you again to replace the switch and have to go through the hassle of returning the old one! icon_wink.gif
Back to top
 Alert Moderators
ggevans
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 26, 2007 9:15 am    Post Subject:
Sorted. Tip - Don't bother with the cheap and nasty! all wired the same and hey presto - dimming lights.
Thanks for all the comments.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wiring a dimmer switch 2 180 Sun Aug 03, 2008 5:54 pm
Wiring up a two-gang, two-way, dimmer switch - help! 9 1300 Mon Aug 30, 2004 10:43 am
Wiring a 2 gang dimmer switch for ceiling and wall lights 2 1740 Tue Nov 07, 2006 7:27 pm
Wiring A Double dimmer switch 17 620 Wed May 06, 2009 1:53 pm
Dimmer switch wiring *peace of mind question* 38 2920 Wed Jan 21, 2004 7:47 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
