Just had an electrician in to do some work on my kitchen before I get it plastered and all the new units put in. I\\\'ve bought a new electric oven and hob both of which have a max rating of 5.8kw. The electrician has moved my cooker point for me and I presume I can run both the oven and the hob off the cooker point but my distribution unit has a 40 amp limit on the cooker circuit.
If memory of my school physics lessons serves me correctly, 5800*2/240 = 48.3 amps which would pose a problem if i were to have the oven and hob all running at full power. Is it possible to upgrade my cooker MCB to a 50 amp one (assuming that the cable used for the cooker circuit is suitable). I know this is probably not strictly necessary as its unlikely that I would be using all 4 rings on the hob and both the top and main ovens at the same time.
The distribution unit i have is a Square D - Qwikline II if that makes any difference.
