KKPB
Joined: 25 Jan 2007 Posts: 3 Location: London, United Kingdom Thanked: 0 times
Posted: Thu Jan 25, 2007 11:14 am Post Subject: REWIRING A FRENCH LAMP WITH ENGLISH PLUG |
Is this possible? and if so how do i do it make sure that the live neutral and earth are all in the correct places? |
FredFlintstone
Joined: 19 Jan 2007 Posts: 543 Location: Cheshire, United Kingdom Thanked: 0 times
Posted: Thu Jan 25, 2007 11:57 am Post Subject: |
It won't have polarity. Therefore, I'd say just connect one wire to the live and the other to neutral on the UK plug
There's a potential issue though. The live connection in the bulb holder needs to be sheilded I think so polarity may apply but it may meet EU standards if it's not an ancient thing.
Alternatively, if you can, just remove the bulb holder and flex and replace it with a new bulbholder and flex. |
KKPB
Posted: Thu Jan 25, 2007 12:08 pm Post Subject: |
Thanks it is from the 1950's!? |
FredFlintstone
Posted: Thu Jan 25, 2007 12:17 pm Post Subject: |
Ooooooh! With a twisty black cord? Is it a screw in bulb?
Might be worth using some sort to tester to make sure you connect the cable to live that connects to the INSIDE of the lamp holder (i.e. the bit that contacts the bottom of the bulb rather than the bit that connects to the threaded part od the holder).
Sorry if that soesn't make sense.
Is it not possible to replace the bulb holder and flex and just keep the base and shade as original? |
KKPB
Posted: Thu Jan 25, 2007 1:34 pm Post Subject: |
It is a jielde french lamp, which has 4 articulated arms, at each joint the electricity is carried through via metal and insulators which means the lamps can move at 180 degrees at each joint, i think re wiring that bit would be fine its just i am unsure at the top.
As an easy alternative what is to stop me using a french travel adaptor for the lamp??
Cheers for all the help |
securespark
Joined: 11 Jan 2004 Posts: 16491 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Thu Jan 25, 2007 3:30 pm Post Subject: |
If it is Class I, then it will require earthing. Is the existing cable in good condition? Can you eyeball the conductors? __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
